February 03, 2026, 05:11:45 PM *
Author Topic: Diiferences in shocks  (Read 11046 times)
Robdawg13
« on: October 28, 2011, 12:53:11 PM »
Thinking about ditching the 11.5" Progressives that came on my bike when I bought it and going with stock shocks.  Honda shows different part #'s for 1997-98 and 1999-03.  What is the difference?
I don't want a pickle
I just want to ride my motor-sickle
« Reply #1 on: October 28, 2011, 01:50:24 PM »
You could get a new pair of progressive 440s or a new set of Works Performance Shocks
for the price you would pay for a new set of OEM Valkyrie shocks...
13 inch is the OEM length, I have 13 inch 440s and like them.
Robdawg13
« Reply #2 on: October 28, 2011, 02:06:58 PM »
Lookin' at a used pair...
Just want to know if they changed the spring rates or something and if the later model part # is any better.
« Last Edit: October 28, 2011, 02:08:42 PM by Robdawg13 » Logged
Valkpilot
What does the data say?
Corinth, Texas
« Reply #3 on: October 28, 2011, 03:51:51 PM »
I think you should buy new.  The OEMs wear out quickly.  I've got a set I'll let you have for the cost of shipping, but with about 55k on them, they let the bike wallow like a pig in turns.
Come to think of it, I might have a set of 13 inch Progressive 412 HDs available soon.  They have about 10k on them.  PM me if you're interested.
« Last Edit: October 28, 2011, 03:54:14 PM by Valkpilot » Logged
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
joebarros1
« Reply #4 on: October 28, 2011, 04:51:24 PM »
Hi. I'm having problems with my 2000 Valkyrie Tourer rear shocks. Bike has only 20K miles.
I am 5'4" only. I lower them, but now the tire stated to drag on the fender. I adjusted two (2)
clicks up and still drags. Right now I can not afford to buy new ones. Any sugestion?
Thank you, Joe.
olddog1946
Moses Lake, Wa
« Reply #5 on: October 28, 2011, 04:59:06 PM »
I've never had a bike that the shocks lasted on..seem to go belly up in 20K or less..and I certainly can NOT understand why motorcycle shocks are soooo expensive...kinda like paying 246 bucks for a tire that only lasts 8K...
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #6 on: October 28, 2011, 05:34:31 PM »
Lets remember that our valks are getting old, in addition to (and regardless of) actual miles per bike.  A 14-10 yo bike with relatively low miles may still have failing OE shocks.
And.... some OE shocks do better than others.... just like Progressives and other aftermarkets.
I am unaware of different shocks from 97-03.... but of course the IS shocks are stiffer than tourer/std, but that would be a different part # for all years.
I would go to 13"s if you can.
I don't know if I'd pay $255 per shock plus new bushings for OE.  They are not bad shocks, but they won't touch Progressive 440s which come with a lifetime warranty.  Or I'd stick 412s on there. The choice of shock should also depend on what kind of riding you do and if you carry a passenger (ballast) more often than not.
08    CUSHION, L. RR.   retail         HDL price
52500-MZ0-A41    001    $348.98    $255.28
http://www.hdlparts.com/fiche_section_detail.asp?section=148238&category=MOTORCYCLES&make=HONDA&year=2000&fveh=3468
« Last Edit: October 28, 2011, 05:36:33 PM by Jess from VA » Logged
« Reply #7 on: October 29, 2011, 12:48:35 AM »
Robdawg.....
Sent you a PM about your shocks.
« Reply #8 on: October 30, 2011, 11:04:15 AM »
Shocks for the Interstate are sprung harder than for the Standard and Tourer.
Phil57
Jenison MI
« Reply #9 on: October 30, 2011, 03:10:28 PM »
OK I will ask the dumb #ss question. The 440 progressive price is around 500-600. Is that a pair or per shock. Rember I already called myself a dunb #ss to save everyone the trouble.
« Reply #10 on: October 30, 2011, 03:44:41 PM »
http://www.hondadirectlineofshadyside.com/stores/product.asp?pid=558&str=2&ID=602438014
donaldcc
Palm Desert, CA
« Reply #11 on: October 30, 2011, 03:52:00 PM »
As link from Jess shows, sold as a pair.
So, I'm thinking about getting a set of these to replace OEM.  I almost ALWAYS ride my Tourer without passenger.  Is there any reason to get the 440 HD?? Undecided Undecided I'm 210lb and do not load up bike very often.
Don
« Reply #12 on: October 30, 2011, 04:15:47 PM »
I would get the standard rate Don (which is called for in PS's info for std and tourer) .  There are 10 preload settings on all 440s (the Std and HD 440s are internally identical, only the springs are different).  All ISs are supposed to use HD.  My IS with trunk sits at the softest setting since 2005, and it is plenty stiff (but good)... but I have no softer setting available (185, no passenger, rarely a load).   I put the standard rates on my permanent supervalk IS, and they sit at 3 or 4 turns from softest.
Save your receipt for the warranty.
Also, you may want to shop Amazon and some other places for the best prices (you might get lucky), then get HDL to price match (plus 5 bux)....... it's better dealing with HDL if there are any issues.  Remember you must add shipping to the other guys price since this will be free shipping from HDL.
Std rate 13" 440 part no is 4213  -   HD is 4412.
Found this.   http://www.amazon.com/Progressive-Suspension-440-IAS-Shock/dp/B000GVD668/ref=sr_1_2?ie=UTF8&qid=1320016210&sr=8-2
$491.22 + $13.09 shipping = 504.31 ($32.68 cheaper than HDL... who will also take off 5 bux on price match)
All of this is for chrome..... black ones are $35-40 cheaper.  (C in part no is chorme.... B in part no is black)
donaldcc
Palm Desert, CA
« Reply #13 on: October 30, 2011, 04:29:30 PM »
 cooldude cooldude
Thanks Jess, very helpful.
Don
« Reply #14 on: October 30, 2011, 05:47:15 PM »
Welcome.  I try to help when I can.
Paxton
So Cal
« Reply #15 on: October 31, 2011, 12:36:39 PM »
I have two sets of OEM's in like new condition. You could have one set for $190 + shipping. ???
I swapped them on the belief that the bike could be lowered. It did some, but not to make it worth the investment that I made.  Sad
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
Hedgehog
« Reply #16 on: November 01, 2011, 09:59:39 AM »
I'm thinking of replacing mine (OE) and was wondering what the real difference is (in real world actual use terms) between the Progressive 416's and the 440's. Quite a price difference - are the 440s worth it?? ???
Dave King
Proud owner of Honda Valkyrie F6C 1997 Standard
& owner of BigBikeMad.com
donaldcc
Palm Desert, CA
« Reply #17 on: November 01, 2011, 10:52:49 AM »
 cooldude cooldude
   I emailed HDL with the link to the Amazon site and they knocked price down $50 from their price of $536.99,($491.22 - $5= $486.22).  And no mark off for the shipping charge of Amazon.  Good customer service!
Here is email from HDL
Thank you for your recent price match inquire at Direct Line Parts.
Your price macth request has been approved. By clicking on the link below you
will be allowed to purchase 1 unit(s) of our part # PRO-4404230CCX at this
price: $486.22
http://www.directlineparts.com/product_wk_spc.asp?pid=558&str=0&flw=0&rc=f19ejmk7zhrzqoozzxzz
Price Match Link Usage Rules:
- To use the link above, during checkout you must login using the same email
address on which this email message was sent to you
- This special price cannot be combined with any other discounts or coupons
- This link expires on: 11/15/2011
Thank you for shopping Direct Line Parts, Inc.
« Last Edit: November 01, 2011, 10:55:54 AM by donaldcc » Logged
Don
« Reply #18 on: November 01, 2011, 12:57:13 PM »
Good stuff.   Cool
AaK ..... 11.5 inchers in HD??
donaldcc
Palm Desert, CA
« Reply #19 on: November 01, 2011, 01:54:58 PM »
Good stuff.   Cool
   cooldude Good eyes Jess.  I spoke to HDL on the phone and they did match the price on the 13"SD shocks.  I didn't notice the different part number in the email.
Don
« Reply #20 on: November 01, 2011, 06:28:53 PM »
I got paid to read the small print for many years.    (Now I can't stop. 2funny)
Plus, this was my recommendation.
I also have several times searched high and low for the best price for some bike part or gear, to frugally save 30 or 50 bux, only to lose it all in return shipping when I got the wrong item/size/part.    crazy2
Paxton
So Cal
« Reply #21 on: November 08, 2011, 12:19:41 AM »
QUOTE from joebarros1:
"... I lower them, but now the tire stated to drag on the fender. I adjusted two (2) clicks up and still drags...
Any sugestion? Thank you, Joe.
Joe; It sounds as if you are running a car tire. If so, you must do a nut-cage-mod under the rear fender. Easy job. Smiley
However, if you are running the correct size motorcycle tire, then it sounds as if your shocks are virtually gone. Sad
If so, then go back up-to the higher setting where the tire won't rub. tickedoff
You ought to check the rubber bushings for cracks or signs of age. Many folks retrofit aftermarket bushings to improve handling. Wink
Mine is a 2000 Valkyrie Standard. I lowered the rear from OEM 13" to the 11.5" Progressives. Did it because like you, I am a short person. coolsmiley
I then did the nut-cage-mod and installed a car tire, the tallest (205/65/16). No rubbing. Roll Eyes
Good luck.
J. Paxton Gomez
So Cal... 91205
olddog1946
Moses Lake, Wa
« Reply #22 on: November 08, 2011, 09:26:15 AM »
While doing some research on progressive shocks I found that their shocks for a valk also fit:
99-05 vulcan 1500 drifter
98-04 vulcan 1500 nomad
03-07 vulcan 1600 classic
86-03 ZG-1200 voyager
04-07 Rocket III
did a search on ebay for those sets of shocks and found a set of rocket shocks off of an 07 converted to a trike with 3K on them for $150....
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Paxton
So Cal
« Reply #23 on: November 08, 2011, 11:59:25 AM »
My OEM VTX 1800's shocks are interchangeable with the Valkyries. They both have now the identical 11.5" Progressives....  cooldude
J. Paxton Gomez
So Cal... 91205
John U.
Southern Delaware
« Reply #24 on: November 08, 2011, 05:24:08 PM »
04-07 Rocket III
I hear the stock Rocket III shocks are pretty bad. $150 might sound like a deal with only 3K on them but it ain't necesarily so.
valkyriemc
NE Florida
« Reply #25 on: November 09, 2011, 08:06:41 AM »
Yes and they last and are also adjustable.
Veteran USN '70-'76
Sigrún
Lewisville, TX
« Reply #26 on: November 09, 2011, 08:44:38 AM »
Hmm I was under the impression they all are? At least mine are in a Standard?
IBA #54465
olddog1946
Moses Lake, Wa
« Reply #27 on: November 09, 2011, 09:21:51 AM »
04-07 Rocket III
That is a distinct possibility,,,any used shock could be a bad buy..but worst that could happen is that I put the old ones back on and resell the rocket shocks..
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Kep
My "Mid-life Crisis "
Indiana
« Reply #28 on: November 10, 2011, 05:47:14 AM »
Just bought a set of Progressive 440-4221C for my 97" Fire Breathin Dragon for $449.00 - FREE SHIPPING (plus got a pair of fingerless gloves as bonus gift) at www.directharleyparts.com.
« Reply #29 on: November 10, 2011, 09:40:32 AM »
Has anyone not thought about using spacers on the springs of a stock shock to gain more strength.
The total travel will be shortened by the thickness of the spacer but the resultant stiffer springing should surely be of greater benefit that the loss of a little bit of travel.
Sparky51
Houston, TX
Houston, TX
« Reply #30 on: November 10, 2011, 05:01:15 PM »
At the Lone Star Rally this weekend, stopped in the Progressive Tent to talk shocks.  Says, yes, they sell a lot of 440's to Valk owners, but he said also, seriously doubted we would feel the difference from the 440's down to the 430s and save about $100.   Yes the 440's are better, but anybody got any experience with the 430's?
valkyriemc
NE Florida
« Reply #31 on: November 14, 2011, 06:46:42 PM »
Yes-poorly written on my part...
« Last Edit: November 14, 2011, 06:48:20 PM by valkyriemc » Logged
Veteran USN '70-'76
Paxton
So Cal
« Reply #32 on: November 14, 2011, 09:10:21 PM »
Hum... the 11.5"  Progressives I put on the Valk must be the rock-bottom cheapos... I paid $250 for the set. Undecided
Notwithstanding, their performance and handling characteristics are superb. Lips Sealed
Just installed the same on the VTX1800... Am just as happy with them. cooldude
J. Paxton Gomez
So Cal... 91205
olddog1946
Moses Lake, Wa
« Reply #33 on: November 24, 2011, 09:51:50 AM »
04-07 Rocket III
UPDATE: Got the Rocket III shocks, changed out the lower bushings (used Gary's poly one's from the original shocks, although the rocket shocks also have poly bushings they are wider) and installed them...much better ride than I had before.  The bike doesn't feel near as mushy and rides smooth on the road..the weather hasn't been good enough to get out for a long ride but I certainly like what I've experienced so far..
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #34 on: November 24, 2011, 09:58:58 AM »
Are the Rocket III shocks 13" also.....or are they shorter?
olddog1946
Moses Lake, Wa
« Reply #35 on: November 24, 2011, 11:17:53 AM »
13"
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
