March 27, 2026, 02:40:34 AM *
Author Topic: Yes or no to purchase of high mileage Interstate!  (Read 1122 times)
Tinggi
« on: October 30, 2011, 01:18:27 PM »
A little advice from the forum on why/why not to buy a 100,000 mile Interstate?
I am not overly concerned about the motor but what other parts will be showing their age by now? Starter? U-Joint? Rubber isolation(?).
2000 for $4500!?
Any and all comments very much appreciated.
Thx
David
Grumpy
Tampa, Fl
« Reply #1 on: October 30, 2011, 01:31:07 PM »
Depends on the PO, how he maintained it. If all service, rear axle final drive lube, etc. If he can produce records, probably not a bad deal. But if he just rode it and did not keep the maintenance up, could be a can of worms.
Tinggi
« Reply #2 on: October 30, 2011, 01:40:35 PM »
Thanks Grumpy.
Will be in contact this week to see what I can find about service records.
David
eric in md
« Reply #3 on: October 30, 2011, 01:44:07 PM »
depends on records and goodys on it ?
Tinggi
« Reply #4 on: October 30, 2011, 01:53:36 PM »
Is there anything that is high dollar to replace/fix? Most things I can wrench myself but I have little interest in tearing a motor down.
David
eric in md
« Reply #5 on: October 30, 2011, 02:08:36 PM »
my bike turn 100k on the way home from fla .. love it more every day.. love it .
« Reply #6 on: October 30, 2011, 02:39:47 PM »
I wouldn't worry about records or anything else like that!
If the tins are good and the paint is good and it has all the Interstate parts still on it, I would only be concerned about how it runs and if everything that is on it works.
All the stuff you mentioned is easily replaceable and parts are available.
The price you stated is a good low price and especially so for a good running Valkyrie.
If you do buy it, make a good buy and be sure you get any extra parts that may be also in his keep. like anything he may have replaced with aftermarket parts such as exhaust pipes or seats.
« Reply #7 on: October 30, 2011, 03:00:51 PM »
4500 is a price good enough to allow you to take care of the items that may need attention.  Set aside $1000 for possible issues and you've still got yourself a fine bike for a great price.
U-joint
Alternator
rubber all around
Pinion
Fork seals
Bearings
Wheel dampers
Shocks and/or bushings
All possibles.  None guaranteed to need replacement.
Tinggi
« Reply #8 on: October 30, 2011, 05:19:34 PM »
Grumpy, Eric in MD, Ricky-D and Willow
The quick response and information very much appreciated. Will let you know how it all turns out.
Thanks.
David
Fritz The Cat
« Reply #9 on: October 30, 2011, 05:21:29 PM »
I would be more concerned about a low mileage bike than a high mileage one. They develop emphysema when they sit too long. Plus, dry rot and other nasty stuff can take it's toll. 100k on the clock means it's been doing what it was made to do.
