August 21, 2025, 10:38:25 PM *
Author Topic: Batwing fairing help  (Read 1286 times)
jarid
sacramento CA
« on: October 30, 2011, 05:06:57 PM »
I just got my dragonfly fairing that soon will be on the valk.I noticed that the speakers are not exactly airtight,what can be done to seal them up some? thanks in advance.
Thinking men cannot be ruled!
DFragn
« Reply #1 on: October 31, 2011, 05:22:14 AM »
Not sure what you mean by "not airtight".
But airtight speakers don't perform to well.
If your concerned about foul weather I would research the brand & type you have installed.
If needed, there are Marine type speakers available. They're built to survive all the water and humidity exposure of boating. Although nothing is 100%.
I have Polk Audio Momo 5.25" [they are marine certified] in my batwing styled type fairing. Had to modify the opening a bit to accept them.
They have an airtight rubber surround that as per Polk "stands up to moisture, sunlight, and extreme temperatures while allowing long excursion linear motion and years of reliable use."
So happens, all my heavy wet weather riding occurred before I installed them. So I'm not able to provide real world defense of the product. But, they've gotten wet [not soaked] from the garden hose and have never failed to perform.
Oh yeah, did I mention that these Polk's sound great, bass, mids & highs, outstanding for a small coaxial speaker that is bi-ampable with inline crossovers, dual-layer voice coil that is melt resistant to 725* degrees.
Sound good at 80+ mph.
If you can get them to fit.
If you have larger speakers in there, look to Polk also.
Just my 2cents and that's all it could be worth.
http://www.polkaudio.com/caraudio/mm/index.php?s=mm5251
I painted my grills to match the fairing so they'd be less conspicuous.
« Last Edit: October 31, 2011, 07:59:07 AM by DFragn » Logged
jarid
sacramento CA
« Reply #2 on: November 01, 2011, 08:09:08 PM »
What I mean by air tight is they are not in a sealed enclosure (like speaker box) if you take the back off a speaker box it will not sound as good as being in a sealed enclosure.Are all batwing fairings open like the dragon fly.
DFragn
« Reply #3 on: November 01, 2011, 10:02:22 PM »
I don't know. I would suspect yes-maybe.
Mine is not an HD fairing and is somewhat open behind the speakers. My internal cavities are not airtight. I enclosed the backside of the speakers inside the fairing with a closed cell foam cup/bucket that was furnished with the Polk speakers. Which contours to the fairings interior confines.
I imagine those foam buckets could be purchased at Radio Shack or a Stereo Center Retailer .
