August 22, 2025, 12:25:43 AM
Carb removal problem
Topic: Carb removal problem (Read 1576 times)
Sambo21
Ponte Vedra Beach, FL
November 02, 2011, 01:16:09 PM »
I'm trying to remove the carbs from my '97. The only thing left is the "upper radiator hose plastic shroud" is in the way and I can't get it out - it's stuck in. The manual says it's got to be removed for clearance. Any idea how to get it out? I don't see any screws or bolts attaching it to the bike.
'97 Tourer
quexpress
Montreal, Québec, Canada
Re: Carb removal problem
November 02, 2011, 02:07:51 PM »
It's been such a long time since I've done mine ... that I have forgotten.
However I vaguely remember loosening the radiator in the front of it. Does it seem to be catching in the radiator fan, etc?
I still have a full deck.
I just shuffle slower ...
Pete
November 02, 2011, 03:27:56 PM »
I do not remove the air deflector when removing the carb.
But I do remove the rear upper engine hangers and the carb to head manifolds.
Carbs come right out the left side.
Blackduck
West Australia
November 02, 2011, 03:42:38 PM »
+1 on the hangers, I never remove the shroud.
I leave the 3 manifolds on the head on the opposite side I am removing the carbs from.
I ususlly take them out the right side, either way they come out easy.
Cheers Steve
quexpress
November 02, 2011, 05:47:48 PM »
Quote from: Pete on November 02, 2011, 03:27:56 PM
I agree ... memory was/is bad ...
Blackduck
West Australia
November 03, 2011, 06:12:38 AM »
I remove both but easy enough to try to remove the carbs then remove hanger as needed.
No need to support the engine.
Remember to cover the inlet ports while you have the carbs off, don't need anything dropping into the cylinders.
Cheers Steve
Pete
Reply #6 on:
November 03, 2011, 06:50:39 AM »
Quote from: Sambo21 on November 03, 2011, 05:50:02 AM
Do I need to remove BOTH hangers? Do I need to support the engine from below when I remove them?
I find it easier to remove the left one. On the right one leave the switch attached, remove the bolts and push it to the rear.
=> InZane XXV
