March 27, 2026, 04:28:38 AM
This sounds fishy (no pun intended)
Topic: This sounds fishy (no pun intended) (Read 819 times)
November 02, 2011, 04:29:05 PM »
Renault and Ford have joined forces to create the perfect small car for women.
Mixing the Renault 'Clio' and the Ford 'Taurus' they have designed the 'Clitaurus'. It comes in pink, and the average male car thief won't beable to find it - let alone turn it on - even if someone tells him where it is and how to do it.
Rumor has it though, that it leaks transmission fluid once a month, and can be a real bitch to start in the morning!
Some have reported that on cold winter mornings, when you really need it, you can't get it to turn over.
New models are initially fun to own, but very costly to maintain, and horribly expensive to get rid of.
Used models may initially appear to have curb appeal and a low price, but eventually have an increased appetite for fuel, and the curb weight typically increases with age.
Manufacturers are baffled as to how the size of the trunk increases, but say that the paint may just make it LOOK bigger.
This model is not expected to reach collector status. Most owners find it is best to lease one, and replace it each year.
RainMaker
Arlington, TX
Re: This sounds fishy (no pun intended)
November 02, 2011, 04:39:51 PM »
Isn't that the one with the built in Nagravation system as a standard feature? The system not only tells you where to go, but gives constant status on surrounding traffic and monitors your speed with warnings.
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
The Anvil
Derry, NH
November 02, 2011, 04:46:01 PM »
...and when you put air in the tires it refuses to have sex with you claiming that it feels "bloated".
November 02, 2011, 06:14:47 PM »
And absolutely positively wants/needs/demands to be left alone when leaking tranny fluid.
And under NO circumstances are we allowed to commune when leaking tranny fluid.
RIDE SAFE.
Last Edit: November 02, 2011, 07:12:55 PM by old2soon
