« on: November 06, 2011, 05:46:35 AM » |
Friend of mine is mounting one on his Valk and if it's bolted down as it's meant to be, the headlight points at the front fender. What has been used by others to mount the VTX 1800 headlight to the Valk? I have a couple ideas for an adapter but if someone has a simple approach, he'd like to hear it.
dreamaker
« Reply #2 on: November 06, 2011, 07:44:34 AM » |
I put a Trike Shop Radio Caddy (batwing fairing) on my Valk and you had to use a VTX headlight and the mounting kit (1300 VTX kit) came with a VTX headlight mount. The VTX and Valk triple trees are very close and the holes line up. Try the Trike Shop .
dreamaker
« Reply #3 on: November 06, 2011, 04:27:07 PM » |
I went on EBay and saw a few VTX headlight mount for around $24 and up.
art
Grants Pass,Or
Grants Pass,Or
« Reply #4 on: November 06, 2011, 04:58:57 PM » |
I have a 1800 vtx headlight on my standard an I used the vtx mount no problem.The vtx an valkyrie have the same forks an tripple trees .maybe he has the 1300vtx light I don't know if there is a difference .I still have the valk headlight an the mount holes look the same
lucky_1_chris
« Reply #5 on: November 06, 2011, 05:06:05 PM » |
The 1300 headlight is the same as at least the '02 1800 C model, and AFAIK all the headlight extensions are the same for all VTX models, so I don't think it should matter.
1999 Valkyrie Interstate
« Reply #6 on: November 06, 2011, 05:07:21 PM » |
I just checked and the headlight bucket is the same p/n for both the VTX 1800 & 1300, but for the mount(stay) p/n is different...the piece that bolts to the tree.
« Last Edit: November 06, 2011, 06:48:16 PM by John Schmidt »
art
Grants Pass,Or
Grants Pass,Or
« Reply #7 on: November 06, 2011, 05:38:08 PM » |
The mounting bracket is diff than a valk but the bolt holes are the same as is the angle of the light.I did not change anything except the mount which is the stock 1800 vtx
lucky_1_chris
« Reply #8 on: November 06, 2011, 07:48:50 PM » |
Not all headlight buckets are the same across the different 1800 models. The mounting bracket may be different between the 13 and the 18 that share the same bucket, but I think the holes in the trees have the same spacing. I can't see how either bracket would leave the bucket pointing at the fender.
Paxton
« Reply #9 on: November 06, 2011, 10:31:48 PM » |
I just installed these headlight extenders on both my 2000 Valk Standard and on my 2002 VTX 1800R.  I bought a 2" extender for the Valk and a 3" extender for the VTX... Both "extenders" are identical in design and do fit both ladies right out of the box...  Their quality and feel is tops! Installation is 10 minutes flat... err... 15 minutes with a Beer in one hand. SEE PHOTOS: https://picasaweb.google.com/103917731019176896112/VTXVALKYRIEHEADLIGHTS?authkey=Gv1sRgCPra65nlldG2ugE
J. Paxton Gomez
1966 First year Bronco... 302 CI V8 1975 First year Chrysler Cordoba... 360 CI V8 1978 Honda 750F / Cafe Racer 2000 GL1500CY Fast-Black Standard Solo Rider
So Cal... 91205
Dag
Country Rep. Norway
« Reply #10 on: November 07, 2011, 04:39:51 AM » |
I made a spacer because it was a big gap between the headlight and windshield. Bracket that came with with VTX headlight I installed did fit without any other modifications.  More: http://valkyrienorway.com/vtxhead.html
art
Grants Pass,Or
Grants Pass,Or
« Reply #11 on: November 07, 2011, 07:45:43 PM » |
Forgot to add I also changeg the windshield to a vtx shield because of the size of the light is diff. vtx light is smaller in dia. an stock valk.shield had a big gap that let in a lot of wind.about $1000 total for both.Not cheap.
Paxton
« Reply #12 on: November 07, 2011, 11:10:50 PM » |
Art; I usually ride w/o a shield, unless I am going on a long trip. My newly acquired VTX came with the OEM-accessory windshield. I went around pricing them and ouch! you are right; they sell for 'round $500 +.  I thought it might fit the Valkyrie, as everything, but the headlight is different. I suppose tomorrow I will find out whether it fits over the Valk's larger Headlight... At any rate, I plan to buy an extra installation kit for the Memphis Shade Batwing that I use on the Valk. The kit would go on the VTX thus allowing my sporadic use of the same Batwing on both ladies. If the Batwing works out for both machines, I might then sell / trade the VTX shield.
J. Paxton Gomez
So Cal... 91205
art
Grants Pass,Or
Grants Pass,Or
« Reply #13 on: November 08, 2011, 09:43:48 AM » |
Art; I usually ride w/o a shield, unless I am going on a long trip. My newly acquired VTX came with the OEM-accessory windshield. I went around pricing them and ouch! you are right; they sell for 'round $500 +.  I thought it might fit the Valkyrie, as everything, but the headlight is different. I suppose tomorrow I will find out whether it fits over the Valk's larger Headlight... At any rate, I plan to buy an extra installation kit for the Memphis Shade Batwing that I use on the Valk. The kit would go on the VTX thus allowing my sporadic use of the same Batwing on both ladies. If the Batwing works out for both machines, I might then sell / trade the VTX shield.  Hi . The vtx shield will not fit over the valk headlight due to the diff. in the dia. of the valk light .I liked the vtx shield because it looked like a better quality frame.I had a good paying job at the time I bought them but now I would think twice about that.
