November 19, 2025, 02:37:29 AM *
Author Topic: the center O-ring  (Read 2460 times)
Cleaner Man
Grand Rapids, MI (actually Lowell- but who knows where that is)
« on: May 04, 2009, 04:57:59 PM »
this is my third question regarding the spline maintenance on my '97 Standard.  When i disassembled the hub, the thin, "center" O-ring was quite thin (compared to the new one), and was broken.  It was obviously destroyed.  I am pretty sure that I did not roll it when doing spline maintenance 6,000 miles ago.  I'm wondering if even the slightest play in the wheel dampers could cause enough movement to destroy this O-ring?
Again- thanks for the great help and comments.
« Reply #1 on: May 04, 2009, 05:39:30 PM »
Matt sells the O-Ring kits he's a VRCC vendor so you can trust him .I change mine everytime the wheel comes off its cheap " Peace Of Mind " .
http://www.carolinabikeandtrike.com/ORings.htm
Dag
Country Rep. Norway
« Reply #2 on: May 04, 2009, 06:18:14 PM »
I do also change mine everytime the wheel comes off, but I have never seen any worn out or destroyed.
Cleaner Man
« Reply #3 on: May 04, 2009, 06:21:24 PM »
My question really is whether the wheel dampers, if even a smidgen loose could cause some travel, or movement that in turn would mess up that O-ring?
« Reply #4 on: May 04, 2009, 07:29:34 PM »
Very doubtful on the damper movement taking out an 'O' ring.
Most of the destroyed one I have seen was due to roll at the last installation..........
That little stock one is very fragile.........
Sharkey
GOT CURVES??
VRCCDS0184
« Reply #5 on: May 04, 2009, 08:15:59 PM »
I will also  cooldude Matt. I paid with paypal and he shipped the same day.
MP
North Dakota
« Reply #6 on: May 05, 2009, 04:52:00 AM »
 cooldude  +1 on Matt.  A fine Vendor.  I use his orings.
"Ridin' with Cycho"
