February 03, 2026, 05:11:36 PM *
Pages: 1 [2]   Go Down
Author Topic: engine damage from starter  (Read 5777 times)
« Reply #40 on: November 18, 2011, 11:41:40 AM »
I would think it would eliminate hydrolock and a bonus would be 3 more gallons of gas. Would not need a petcock either, unless you wanted to remove the main tank with gas still in it.  Hoser   Smiley
ptgb
Youngstown, OH
« Reply #41 on: November 18, 2011, 12:13:10 PM »
Farther wouldn't that eliminate hydrolock ?
...Would not need a petcock either, unless you wanted to remove the main tank with gas still in it.
Not Farther, but yes it would eliminate hydrolock as now the fuel is not gravity fed from the fuel tank it is pumped up from the belly tank.
The belly tank does not eliminate the petcock, it is still on the tank and is attached via hose from main tank to belly tank. During normal operation the petcock is a vent for the belly tank. The petcock is used when you turn it to reserve as it drains the remaining "reserve fuel" down to the belly tank. The petcock then becomes a vent again.
My install:
http://www.valkyrieguy.com/bellytank.htm
« Last Edit: November 18, 2011, 12:16:56 PM by ptgb » Logged
BIG--T
The Twilight Zone
« Reply #42 on: November 18, 2011, 01:23:15 PM »
Removing the tank with a little gas in I'm used to with my other bike. cooldude
BIG--T
The Twilight Zone
« Reply #43 on: November 18, 2011, 01:26:30 PM »
where would be the best place to get the belly tank and fuel pump?
ptgb
Youngstown, OH
« Reply #44 on: November 18, 2011, 01:32:06 PM »
This is who makes and sells them... good guy.
http://www.rmworksinc.com/
BIG--T
The Twilight Zone
« Reply #45 on: November 18, 2011, 02:06:36 PM »
Thanks, it looks like I'd have to take off my jack adapter.
ptgb
Youngstown, OH
« Reply #46 on: November 18, 2011, 02:34:48 PM »
Yep, but he even talks about that as well...
http://www.rmworksinc.com/Lift.html
BIG--T
The Twilight Zone
« Reply #47 on: November 18, 2011, 02:56:47 PM »
Thanks, so that's $450 for the tank, where would I find the fuel pump or is it built in?
ptgb
Youngstown, OH
« Reply #48 on: November 18, 2011, 03:48:18 PM »
Fuel pump is part of the unit. All the parts you need come with it. The only extra thing you have to do is have the new fitting (included) silver soldered into the OEM fuel tank. I couldn't find anyone nearby that silver soldered anymore, so I had an aluminum fabricator TIG (not MIG) weld in the fitting. It cost me $25 for that.
The fuel pump that is attached to the tank is a common one, so if it ever needs replacing, I guess they are readily available through places like NAPA.
I don't have the belly tank anymore, but my brother bought it and has it on his Tourer, it has been going without problems for about 4 years now.
BIG--T
The Twilight Zone
« Reply #49 on: November 18, 2011, 04:39:46 PM »
Thanks ptgb for all the help! cooldude
Farther
Quimper Peninsula, WA
« Reply #50 on: November 18, 2011, 06:37:17 PM »
Yes, while the ignition is off.  I have often wondered what would happen if the fuel pump ran while the engine is not running.
~Farther
Pages: 1 [2]   Go Up
