November 23, 2025, 04:21:45 PM *
Author Topic: installing a dan marc fuel valve  (Read 1112 times)
justooneez
« on: November 09, 2011, 05:56:36 PM »
Hi, this is probably a dumb question, but I never installed a fuel valve before, and wondering if I should teflon tape the brass nipples before I screw them into the body, or just tighten a bit past finger tight.  didnt know if the gas would eat the tape or not  Undecided
thanks again for the good site and info Smiley
3W-lonerider
Shippensburg Pa
« Reply #1 on: November 09, 2011, 06:24:40 PM »
gas will not eat the tape..but personally i would use the liquid teflon..if a little peice of that teflon tape gets into the fuel line it could end up sticking a float open or if it gets past the neddle valve it could clog a jet up..keep in mind..gas will leak out of cracks that even water can't get threw..i would deffeinatly seal those threads.
