November 23, 2025, 04:08:18 PM
99 Valk Ignition system
Topic: 99 Valk Ignition system (Read 938 times)
namsgt1946
November 11, 2011, 09:55:06 AM »
Hello! Need a little help with a basket case Valk I am building. I have no electricals other than the wiring harness. Is there any after-market systems that can be used easily and would be better than stock box----or shouild I start searching for used parts. Thanks
Re: 99 Valk Ignition system
November 11, 2011, 10:57:01 AM »
I think it all depends on what you want to end up with.
If you are building an IS, then you'll need a full fuse box. Building a custom rod, then just what you need to run the bike and head lights, wire it yourself.
If you have a bike with a burnt electrical system, then replace it. Try to find someone who has all the parts, you will get the quickest, fair price. If you have all the time, then buy cheap deals on ebay over the next year, and make this a long project.
=> InZane XXV
