November 23, 2025, 04:08:19 PM
valk won't start-again
Topic: valk won't start-again (Read 1232 times)
mario
NW Houston, TX
November 11, 2011, 10:12:08 AM »
the valk won't start-again. tim cleaned the starter switch 2 weekends ago and it started a bunch of times, in the garage.
i just went out to start it,
i turned the key, panel lights came on, pressed the starter heard a little click and then nothing, everything went off. now no lights are on and nothing. is it the ignition?
Mario
01 Valkyrie Standard (sold)
12 Suzuki V-Strom 1000
Re: valk won't start-again
November 11, 2011, 10:30:53 AM »
Sounds like your battery has gone South on ya.
Try to start it with jumper cables off of a vehicle NOT RUNNIG.
If it starts, battery shot.
If it still just clicks, then start cleaning battery posts and checking the ground cable of the battery for good contact.
November 11, 2011, 10:33:57 AM »
Keep us posted.
Valkpilot
What does the data say?
Corinth, Texas
November 11, 2011, 11:15:47 AM »
Quote from: R J on November 11, 2011, 10:30:53 AM
+1
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
mario
NW Houston, TX
November 11, 2011, 11:24:30 AM »
Thanks guys! I was 'hoping' that's all it was!
I'll get back to ya...
Mario
mario
NW Houston, TX
November 11, 2011, 07:48:30 PM »
so i went out this evening and the valk started. checked the battery connections and they were loose. cleaned and tightened. hopefully problem solved.
Mario
shortleg
maryland
Reply #6 on:
November 12, 2011, 09:22:07 AM »
I have found when the Valk will not start to do one
thing first:
Ask myself what was the last thing I did or touched.
Most of the time it has worked because our Valks are
a darn good bike.
Thanks for letting us know.
Shortleg[Dave]
=> InZane XXV
