February 03, 2026, 06:45:36 PM *
Author Topic: Final question on rear end service  (Read 1781 times)
theredark
Derry, NH
« on: November 13, 2011, 01:28:10 PM »
Hi all,
Everythings torn down and cleaned, first time I've done this.  All splines and teeth look good.  No other problems.
I have two containers of grease.  I would like to not buy another if possible.  I have the Bel-Ray Waterproof Grease and the Bel-Ray Assembly Lube.
I've read countless posts and plan on the following,  please correct me if I'm mistaken.
Going front to back:
-Output shaft to U joint - fill the female side of the U joint with grease to top of teeth
-U joint to driveshaft - fill the female end of the U joint with grease to top of teeth
-Driveshaft to pinion cup - fill pinion cup with grease to top of teeth
-final drive splines - coat sparingly with assembly lube
-thrust washer, orings (3) and final drive mating surface - coat sparingly with assembly lube
My concerns are how much grease or paste to use (without weighing it)?   Am I risking by not using moly grease in the pinion cup?  Should I just mix the two of them together there?  Thanks as usual,   Brad
2000 Black/Red Interstate
John U.
Southern Delaware
« Reply #1 on: November 13, 2011, 02:51:58 PM »
I think the manual calls for moly on the drive splines and grease everywhere else except maybe the thrust washer.
I do just as you've mentioned, I mix waterproof grease with Belray assembly lube. I've been using Green Grease but the Belray grease will work just fine.
I've had no problems with that method, I started doing that when I found the drive splines almost dry after 8,000 mile using assembly lube only; that was warning enough for me.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #2 on: November 13, 2011, 04:08:24 PM »
Hi all,
Basically, per the manual, use paste inside the pumpkin and hub.  Use grease everywhere else (pinion, drive shaft, and u-joint.)
Those who service the rear end frequently and regularly often use grease everywhere.
Grease in the pinion and on the drive shaft should be used somewhat sparingly.  I think the manual calls for 2 grams per application point, which ain't much -- about the weight of two paperclips.
It is important to clean the pinion cup well, including clearing out the weep holes in the bottom that are half-hidden by the flange nut that holds the pinion cup to the drive.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #3 on: November 13, 2011, 07:57:51 PM »
Based on that and belief that final drive oil lubricates the pinion end of the shaft, I made
sure the holes in the bottom of the pinion cup were clear last time I changed tires and
put just a little (didn't have a way to measure 2 grams  coolsmiley ) grease there, and
found this there the next time I changed tires...
Seems good to me...
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #4 on: November 13, 2011, 08:03:18 PM »
There is one thing that is for sure:
This will not be the "Final question on rear end service."
Save a horse, ride a Valkyrie
