February 03, 2026, 06:47:00 PM
Two Wolo Air Horns?
Topic: Two Wolo Air Horns? (Read 1664 times)
peregrine
Have Motorcycle, will Conquer
Austin TX
Two Wolo Air Horns?
November 14, 2011, 05:55:42 PM »
Just wondering if ANYONE has installed two (one on each side... I would think) compact air horns like the Strebel or Wolo? Two would be louder I would think (two is better than one.). Or Not.
Let me know if you've tried this... I am getting tired of my stock OEM horn and have installed these type of horns on other bikes... just never two.
gordorad
Washington, MO
Re: Two Wolo Air Horns?
November 14, 2011, 06:10:23 PM »
I didn't install them, but I have two installed under the Valk........Not even sure where the compressor is located....But theu are horny!!
Support the Arts!!
www.gordonradfordphotography.com
November 15, 2011, 06:12:10 AM »
I have seen an Interstate with one in each pod. Won't fit if you have the stock driving lights in the pods. Loud! Hoser
Valker
Wahoo!!!!
Texas Panhandle
November 15, 2011, 10:57:54 AM »
I mounted two, one on each side pointed forward. Plenty of noise, more than one, but not twice as loud. Great response from encroaching cage drivers.
BradValk48237
Oak Park, MI
November 15, 2011, 12:06:25 PM »
I have a stebel in each pod..... equal opportunity for loud here....
B
3W-lonerider
Shippensburg Pa
November 16, 2011, 01:18:04 PM »
i used to run 2 stebil air horns..1 in each pod..each horn had it's own relay..the reason i took 1 out and just running 1..is because when hitting the horn button my volt meter was dropping below 12 volt. with only 1 horn it only drops to 13.2 volt
Reply #6 on:
November 16, 2011, 05:02:43 PM »
One should be plenty loud. You don't want that cager to loose total control. Or do you want them to "sheet" their pants?
My rides:
Reply #7 on:
November 17, 2011, 08:53:09 AM »
I look at loud horns as akin to a 9mm.
Nice to have, but wouldn't want to use it, if you know what I mean.
RP#62
Gilbert, AZ
Reply #8 on:
November 17, 2011, 04:33:16 PM »
Quote from: Ricky-D on November 17, 2011, 08:53:09 AM
That changes when you're almost killed a few times. . . .on both counts.
-RP
