February 03, 2026, 06:45:24 PM *
Author Topic: How do I test the Choke?  (Read 1929 times)
Paxton
So Cal
« on: November 14, 2011, 09:41:03 PM »
All throughout the riding season the Valk would start w/no problem. I really could not tell any difference in firing up whether I used the choke. Undecided
So, I stop using it. ???
Now, as it is beginning to get chilli out there, getting her to start requires patience. I am now "using" the choke again, but it does nothing. Angry
When I move the choke handle, it does so freely. I feel no resistance or engagement of any kind.
Is it possible that something might have come undone? Cry
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
tank_post142
south florida
« Reply #1 on: November 14, 2011, 09:52:25 PM »
pull the cover off the left carb linkage. then move the choke it should move the linkage that engages the choke. chances are you are just not twisting the choke on far enough. once the choke lever stops moving give it a stronger push and it will probably engage the choke then. mine travels over 1/2 before it starts to move the linkage.
I got a rock Sad
VRCCDS0246
CajunRider
Broussard, LA
« Reply #2 on: November 15, 2011, 12:30:57 AM »
+1
When it feels like you're about to break the lever, you're starting to actually engage the choke.  Another 1/2 inch or so from that point, and you're in "choke" mode.
Sent from my Apple IIe
Daniel Meyer
The State of confusion.
« Reply #3 on: November 15, 2011, 02:16:08 AM »
Yep, after free travel stops...push it some more. You are not engaging it. Most every valk I've seen is the same way.
CUAgain,
Daniel Meyer
9Ball
« Reply #4 on: November 15, 2011, 03:31:55 AM »
you can visually see the enricheners move without removing the linkage cover....just get a flashlight and look carefully while moving the lever...you should see the linkage move and the enricheners slide out.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #5 on: November 15, 2011, 06:05:46 AM »
If it does not move and you are completely at the bottom, the cable could be broken, you can set the choke by hand if you push it open on one of the sides or the other, cable is around 20 bux at HDL, not hard to replace.  Hoser
« Reply #6 on: November 15, 2011, 08:19:48 AM »
This is the best and easiest to use advise in determining if you are truly activating the "choke" system on the bike.
« Reply #7 on: November 15, 2011, 09:55:27 AM »
The choke system on the Valk is by far the dumbest thing Honda ever came up with. When I installed the HD controls I lost that goofy lever so had to come up with a new choke activation. This is what I did and it works perfect....plus I think looks kinda neat.  Wink  The first picture is "under construction" and the second one is the finished project. Nothing more than polished SS and a couple small nuts/bolts to attach it. You'll notice there is some shaping to be done to allow the flat actuator to move around some of the carb parts. It will last a lot longer than the cable running from the handlbars down, and holds any position you set it on.
« Reply #8 on: November 15, 2011, 04:51:49 PM »
That is pretty nifty.  Hoser  cooldude
CajunRider
Broussard, LA
« Reply #9 on: November 15, 2011, 11:03:53 PM »
Nice setup there, John...  I'll have to remember that when my cable breaks.   cooldude
« Reply #10 on: November 16, 2011, 06:30:55 AM »
By using the long rod that holds the carbs together you can mount an "L" shaped bracket to the back end of it. Just loosen and back off the nut at the front of the carbs gives you enough slack at the back for the bracket. The rest is just a drill and bolt it down application as you see it. Be sure to use nylock nuts so you can tighten it to the point where it will stay put when you use the choke. The time consuming part was grinding out the sections on the long rod to clear the carb parts. Was a rainy afternoon project that only took a couple hours.
« Reply #11 on: November 16, 2011, 10:22:06 AM »
One way to see where your choke is I use the 'seam' of the controls. When the choke is fully on, it will be at the seam.
valkyriemc
NE Florida
« Reply #12 on: November 17, 2011, 11:16:00 AM »
Like this,  follow link for pics;
http://www.valkyrieforum.com/bbs/index.php/topic,25677.msg232379.html#msg232379
Veteran USN '70-'76
Westsider
Fort Worth TX.
« Reply #13 on: November 17, 2011, 11:38:09 AM »
Yes Sir ,,that time of year here too...time to clean and sillicone the ole choke lever and linkage again. cooldude Finnally valk riding season...
