February 03, 2026, 05:12:48 PM *
Author Topic: Colored spark plug leads  (Read 1412 times)
tmfp
The south west of England
« on: November 20, 2011, 01:12:01 PM »
Do such things exist, with caps, 'boots' and cut to length, straight bolt on job?
 Smiley
Blackduck
West Australia
« Reply #1 on: November 20, 2011, 02:41:32 PM »
Have never seen or heard of plug and play sets. There are coloured leads avaialble but you would need to do the work to change them out.
Only other option would be to use coloured heat shrink. The boots would have to stay black unless you can find something to "paint" them with. There is a rubber type product that was designed for dipping hand tools into to give a rubberized coating on the hand grip area. The main thing to watch there would be any coating needs to be electrical resistant to prevent the plugs from miss firing.
Cheers Steve
Madmike
Campbell River BC, Canada
« Reply #2 on: November 20, 2011, 04:01:35 PM »
Cheers Steve
Wonder what is available for teh Goldwings and whether they would fit the same (3 coils??)
found this  http://store.newlevelmotorsports.com/nohospplwi1931.html
« Last Edit: November 20, 2011, 08:23:02 PM by Scott in Ok » Logged
Bone
« Reply #3 on: November 20, 2011, 04:11:01 PM »
Just did a search in the old tech archives using "colored plug wires". Got 32 hits from 2003-2005. Didn't read any of the posts.
« Reply #4 on: November 20, 2011, 04:28:29 PM »
Here's a writeup I did on changing out my plug wires a few years back. They seldom, if ever, really need replacing but I did it for the looks more than anything.
http://www.valkyrieriders.com/ShopTalk/plugwires.pdf
« Reply #5 on: November 20, 2011, 04:37:39 PM »
Looked over your link, Thank you, now I have an idea how that works.
How about the coil side? It looks like you just unscrew the end of the lead from the coil, but I haven't seen anything that says they are removeable. A picture?
« Last Edit: November 20, 2011, 09:03:02 PM by gordonv » Logged
« Reply #6 on: November 20, 2011, 04:52:48 PM »
there are no "bolt-on" kits.
u have to cut your own, hardest part is fitting the new wires into the coil ends.
 www.magnecor.com  if your racing the best to use
I use moroso wires
« Reply #7 on: November 20, 2011, 05:14:10 PM »
Looked over your lonk, Thank you, now I have an idea how that works.
That's right, the cap unscrews and there's a couple pieces near the end of the wire, works almost like a compression fitting. OEM wires are 7mm so if you use that size you won't have to trim the ends to fit in the caps. Likewise, using 7mm makes it easier to remove/install the new wires in the rubber boots. The trick there is to use plenty of alcohol to lube it. They'll slip right off/on, the alky evaporates and doesn't leave a residue. The OEM wires are solid stranded so I used the same thing.
