February 03, 2026, 05:11:39 PM *
Author Topic: brake life.  (Read 1953 times)
Thespian
Bonny lake Washington
« on: November 26, 2011, 10:10:50 PM »
 Just got my Val, ,6,000 mile's ago. po said the oil spot on the floor was old, but ended up the fork's had a leak and I had to replace the seals and the front brakes ,as soon as I bought it.
  @ 7,000 miles the front brakes are down to 50%. Is this nominal?  Shocked
Also getting allot of drag on the left front caliper after re instillation.
 With no brakes, everything spins good. Right side OK left is dragging.
took the caliper apart and everything looks and works ok. but still I get drag.
Any input is welcome.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: November 26, 2011, 10:15:21 PM »
I'd bet the front axle isn't completely in. It should be flush with the left fork. Check that first.
« Reply #2 on: November 26, 2011, 10:19:17 PM »
Totally agree with Valker's answer.     Axle not seated properly, or, knocked in flush, what ever ya wish to call it.
PhredValk
Edmonton, Alberta, Canada
« Reply #3 on: November 26, 2011, 10:21:56 PM »
I have 24K on mine with the pads that were on her when I bought her. I have new pads in my kit, but am some time away from needing to change them.
Fred.
VRCCDS0237
Thespian
« Reply #4 on: November 26, 2011, 10:38:24 PM »
 I will R&R the front axle tomorrow. I was thinking I needed to start over and see what would happen. Roll Eyes
If at first you don't succeed try try again. cooldude
 Thanks for the timely reply's. cooldude
9Ball
« Reply #5 on: November 27, 2011, 03:36:27 AM »
follow the instructions for re-installing the axel and the order to tighten the pinch bolts.  You also have to bounce the forks a few times before final tightening of the last pinch bolts.
It's all clearly laid out in the instructions...
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Bone
« Reply #6 on: November 27, 2011, 06:26:21 AM »
Shoptalk, owners handbook, owners manual.
« Reply #7 on: November 27, 2011, 06:33:33 AM »
If a person wanted to read the instructions, where would they be located?
Here's one place:
   http://www.valkyrieriders.com/shoptalk/TireChangeSplineLube.htm
Dag has the entire manual online here, you can download a PDF...
   http://valkyrienorway.com/download.html
RonW
Newport Beach
« Reply #8 on: November 27, 2011, 06:34:04 AM »
the instructions are about the same for most bikes however the sequence should be followed religiously. With the axle in the front wheel and through the front forks ....
  • torque left fork pinch bolts (16 ft-lbs)
  • then axle bolt (nut) on right fork (67 ft-lbs)
  • then straddle the bike and bounce the forks up and down applying front brake.
  • finally torque right fork pinch bolts (16 ft-lbs)
in that order. However before Step One of torquing the left pinch bolts it's essential (as others have noted) that the left end of the axle shaft is flush with the outside surface of the left fork. To ensure the flush alignment, you can either pound in the left end of the axle shaft with a rubber mallet with the left pinch bolts loose of course. Or with the left pinch bolts loose, tighten the axle bolt (nut) on the right-side fork to draw in the axle shaft fully into the left fork recess. Two wrench are needed for the second option. Also, with the second option, the steps would be out of sequence or transposed, er, instead A then B, it was B then A, that is, if you were to immediately torque down the left pinch bolts leaving the already tightened axle bolt as is out of convenience. To restore the proper sequence, loosen the axle bolt and start from scratch following the steps above. Bouncing the forks up and down supposedly aligns the axle shaft to both forks. How many repetitions? Personally, I do 8 reps. It's also a good idea to double-check that the speedo housing hasn't been rotated away from its stop lug, here.
(In the process of aligning the front forks, some people loosen the 4 pinch bolts on the lower triple bridge (18 ft lbs) and remove the windshield bolts and windshield as well to preclude locking in any built up stresses imaginary or real. However, after bouncing the forks up and down .... the question is do you torque the lower triple bridge pinch bolts BEFORE tightening the [edit] right fork pinch bolts or the visa versa? If removed the windshield goes on last. With the lower triple tree pinch bolts, dunno.)
« Last Edit: November 27, 2011, 04:37:01 PM by RONW » Logged
2000 Valkyrie Tourer
RP#62
Gilbert, AZ
« Reply #9 on: November 27, 2011, 08:05:09 AM »
As others have noted, this is one area where the instructions in the manual are deficient.  They leave it to you to get the wheel positioned with the rotors centered in the calipers by trial and error.  That is, it gives the instructions for torquing everything down, then has you check that the rotors are properly positioned, which if they aren't means you have to take everything loose again and start over.
It should tell you in the dissassembly instructions, to note the position of the left side of the axle relative to its depth in the lower fork as you will need to reinstall to the same depth.  This would save you a lot of grief later.
-RP
« Reply #10 on: November 27, 2011, 08:15:54 AM »
I hate injecting myself into the fray but the following should not be allow to go unchallenged.
The above quoted directions are all wrong!
Simply put:  If the axle is allowed to stick out too far from the shock you will have interference from the brake rotor mounting grommets hitting the brake caliper mounting bracket.
This is what the bouncing is all about. To be sure the axle is not sticking out too far from the shock.
RonW
Newport Beach
« Reply #11 on: November 27, 2011, 09:27:18 AM »
what the ever are you talking about? There's not a whole lot of steps involved. Once the axle is stuck in the wheel through the forks, there's only 5 bolts to mess with. I believe I quoted the proper order of said steps. Again, what are you talking about. Happy Sunday, btw.
« Reply #12 on: November 27, 2011, 12:32:57 PM »
You don't have to remove the axle to fix this. Loosen all 4 pinch bolts. Loosen the axle nut. Tap the axle in from the left side: it must be seated all the way. Tighten the leftside pinch bolts(drivers side in a cage). Bounce the front end up and down 2-4 times. Tighten axle bolt (67 ft/lbs) and then tighten right side pinch bolts.
« Reply #13 on: November 27, 2011, 12:58:12 PM »
It gets old seeing stuff like this........do you just dream this stuff up and then see who will bite.........  If you are going to post on the Tech board, please stop posting made up junk.
How in the world can "the bouncing thing" detect or correct an axle not seated all the way.....it cant.....I really think you are just taunting to see who will bite.
Stop it please
9Ball
« Reply #14 on: November 27, 2011, 01:47:54 PM »
this is good advice...
Also, get hold of the Honda Service Manual...that's where the directions come from.
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Thespian
« Reply #15 on: November 27, 2011, 02:51:36 PM »
 Thanks again everyone. cooldude I feel a little foolish for not paying attention to the instructions for the front, after making sure to do so on the rear. Embarrassed I didn't torque the pinch bolts at all. It looks like the PO used a roto hammer to put them in last time, they are so bad. Shocked I felt lucky to have broken them loose. Ordered replacements. They should be here mid week.
 I'll try the bouncing the front end thing for good measure. coolsmiley Who knows maybe a apex bit will drop out from under the fender. Cheesy
Bone
« Reply #16 on: November 27, 2011, 04:06:01 PM »
Your lucky you did this work. Even a dealer can mess up the job and some try and hide the damage. Imagine the inconvenience and cost if you had to do the job on a trip. Don't hesitate to ask questions.
SigrĂșn
Lewisville, TX
« Reply #17 on: November 27, 2011, 07:20:32 PM »
Oh they can and they will  Angry
IBA #54465
Thespian
« Reply #18 on: November 27, 2011, 09:20:50 PM »
 The fat lady is no low maintenance ride. But she will, no doubt give back what she is given.  cooldude
