February 03, 2026, 06:40:39 PM *
Author Topic: I/S piggy length???  (Read 1549 times)
custom1
01 Interstate
SW Pa
« on: December 03, 2011, 10:01:26 AM »
I am working on a way to replace the piggies on my I/S. The original owner cut them and drilled some of the baffles. What is the length of the originals. Are they all the same or staggered? I am sort of doing an experiment to see if I can get rid of the drone even though the baffles are drilled. I can make them all straight because I am going to use the 4" truck stacks that came with it.
Thanks John
John
moreira72
VRCC# 33494
Clark, NJ. 07066
« Reply #1 on: December 03, 2011, 10:24:28 AM »
The piggys on my I/S are all the same lengh. They look like they are about 1/2 inch shorter than the exhaust tip
« Last Edit: December 03, 2011, 10:31:15 AM by moreira72 » Logged
custom1
01 Interstate
SW Pa
« Reply #2 on: December 03, 2011, 10:53:41 AM »
Can you tell me the length of the stock exhaust tip? I don't have one, just the stacks.
The stacks start turning before the end of the bags, so I may not be able to make them as long as the originals anyway. I may play around with the lengths to try and "tune" the sound some.
John
moreira72
VRCC# 33494
Clark, NJ. 07066
« Reply #3 on: December 03, 2011, 10:59:47 AM »
The stock exhaust tip is 15 Inches long. and the factory muffler can and heat shield are 18 inches long
custom1
01 Interstate
SW Pa
« Reply #4 on: December 03, 2011, 11:04:13 AM »
Ok Thanks. I'm off to the garage. Will start a new thread with the results and pics if this works.
John
« Reply #5 on: December 04, 2011, 10:21:35 AM »
Those four inch truck stacks are probably more responsible for the drone that bothers you than the three little piggies that are in each end of the stock mufflers.
I doubt you find any relief with a re-do of the piggies.
The length of the exhaust protruding out from the rear of the bike will have a greater affect on attenuating the drone. Again, the direction to where the exhaust is pointed is also a large part of the drone equation.
Helmets are seeming to be the largest co-conspirator when discussing drone, so picking a helmet becomes very important when hoping to reduce the drone effect.
custom1
01 Interstate
SW Pa
« Reply #6 on: December 04, 2011, 08:38:55 PM »
Sorry to disappoint Ricky. Actually you are right. It is the stacks that cause the drone. Adding the piggies eliminates the stacks. Please see the thread here. http://www.valkyrieforum.com/bbs/index.php/topic,35893.0.html
John
