November 19, 2025, 02:39:22 AM *
Author Topic: Standard Maint. Intervals  (Read 2681 times)
whiteytr10
« on: May 06, 2009, 01:47:08 PM »
I like a little feedback on sugggested service intervals. Are there some general intervals where certain items should be changed / tuned ?? I just bought '99 Standard and the previous owner appeared to be pretty good about the oil, maybe a little proactive ( every 3,000 ). The bike has 28,000 on it and I'd like to keep it up to date. I'm sure some of it is subjective but any recommendations would be appreciated. Thanks.
« Reply #1 on: May 06, 2009, 03:34:34 PM »
not sure right off hand but if you have the owners manual they are schedualed mnt listed there.
Duey
Rochester, MN
« Reply #2 on: May 06, 2009, 04:35:55 PM »
http://twowheeled.net/
Earl in Pensacola
« Reply #3 on: May 06, 2009, 05:39:23 PM »
T
Earl in Pensacola
« Reply #4 on: May 06, 2009, 05:46:51 PM »
TWO THINGS FOR SURE!  You do not need to adjust the valve every 12K, unless you like to keep "red lining" the tach.  I did the 12K adjustments a few times, but everything was either on the money or not more than maybe one valve out maybe 1/1000, so now I do it every 35K.  By-the-way, my '97 Tourer is up to 205K now.  The second item is:  With each new rear tire have the shaft pulled out so as to inspect, clean and lube the flange gear teeth etc.  Needless to say the same goes for the spline end.
Just my 2 cents
« Reply #5 on: May 06, 2009, 06:14:38 PM »
oem airfilter will last longer than 12k. I tested a brand new filter against one with 10k on it and there was no difference on the airflow meter using a spare airbox I have. The 10k one looked dirty but it means nothing. there were similar test done on www.bobistheoilguy.com with car filters. They also last must longer than the recomended changeout. I guess the filter manufactures want to sell more filters like the 3k mile oil change interval recomended by the oil companies.
