February 03, 2026, 06:45:14 PM
Drag bars
Topic: Drag bars (Read 1325 times)
Bebop
Drag bars
December 07, 2011, 02:02:37 PM »
Does anyone know if the drag bars off of a Suzuki c50 will fit my standard? Is thee anything I should look out for? Thanks
Disco
Republic of Texas
Re: Drag bars
December 07, 2011, 07:04:05 PM »
Do you have a picture or link to the bars you are thinking of? The only pictures of C50s I found show a top clamp similar to the Valkyrie, and as long as the C50 bar is 1", they will work with the Valkyrie's top clamp. I can't comment on the cables. If the bars you are thinking of replace the stock C50 bars and risers and mount straight to the top of the triple tree, as long as the spacing between the C50s risers is 100mm (4") you should be fine. But again, I can't comment on the cables.
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
VRCC 27,916 IBA 44,783
