February 03, 2026, 06:45:28 PM *
Author Topic: Rear Spline  (Read 1415 times)
Jruby38
Oxford Mass.
« on: December 12, 2011, 12:35:22 PM »
Does anyone know the part no. for the rear spline (I think it's called ) thrush washer? Can't find it on HDL parts diag.
custom1
01 Interstate
SW Pa
« Reply #1 on: December 12, 2011, 01:27:12 PM »
42616-MAJ-G20
#5 in the Rear wheel Diagram I believe.
http://www.hdlparts.com/fiche_select1.asp?cat=Motorcycles&mfg=Honda
Go to the link and look for your year and model and the rear wheel diagram.
John
Jruby38
Oxford Mass.
« Reply #2 on: December 12, 2011, 02:05:31 PM »
Thanks, now I see it.  Should I replace it with every tire change?
« Reply #3 on: December 12, 2011, 08:49:21 PM »
I replaced mine at 62K. Now I have 124K so it's about time. Maybe next tire change.
Daniel Meyer
The State of confusion.
« Reply #4 on: December 13, 2011, 12:00:21 AM »
The thrust washer? No. It's nylon or teflon. It's purpose is to keep the star from rubbing/eating on the wheel at the bearing surface...replace it if worn or cracked. DO NOT run without one. Wheels are expensive!
CUAgain,
Daniel Meyer
