February 03, 2026, 06:40:42 PM *
Author Topic: Oil filter, which one to use?  (Read 2332 times)
alph
Eau Claire, WI.
« on: December 15, 2011, 03:29:55 PM »
Alright, I took the oil filter for my daughter’s car and noticed that it would fit the Valkyrie.  The question is, is it a good idea?  It’s bigger, so wouldn’t it “filter” more oil?  What about flow?  Is there a way to figure out the flow rate of a filter?  It does fit, and doesn’t knock into anything.
I was wondering if the fewer holes around the screw affect the amount of oil flow?  The filter on the left is the one I’ve used over the years; the one on the right is the one that fits my daughter’s car, and the Valkyrie
Any ideas or input would be greatly appreciated.
Al.
junior
new hampshire
« Reply #1 on: December 15, 2011, 03:38:25 PM »
never use a fram oil filter. they atr the worst ones on the market
John U.
Southern Delaware
« Reply #2 on: December 15, 2011, 03:59:39 PM »
The Purolator PureOne filters are some of the best made. The PL14610 is  the same diameter but longer than the stock filter but fits well and contains more filter media. The PureOne PL14459  is the same lengthbut fatter than the stock filter. It offers still more filter media and also fits well. Amazon has them for about 6 bucks.
The SuperTech AT7317 is also longer but same diameter as stock. It's a well built filter and less expensive than the Purolator PurOne.
+1 on don't use Fram
John U.
Southern Delaware
« Reply #3 on: December 15, 2011, 04:01:40 PM »
Sorry, I meant to mention that the SuperTech filters are sold at Walmart.
Bone
« Reply #4 on: December 15, 2011, 04:07:47 PM »
I've used the ST 7317 for 75k miles. There is a study somewhere explaining flow rates and filter media I will see if I can find it interesting reading. I think the ST 3593A is just a little smaller in capacity.
« Reply #5 on: December 15, 2011, 04:08:21 PM »
Filters are like comfort food.
Make you feel good.
Little benefit.
« Reply #6 on: December 15, 2011, 05:00:59 PM »
Any ideas or input would be greatly appreciated.ded.   :
That there supertech is the same as I have used for 94000 trouble freemiles .  It is big enought to take 4 quarts of oil instead of the 3.9 recommended cooldude:  Hoser
« Last Edit: December 15, 2011, 05:03:00 PM by Hoser » Logged
Canuck
Palmetto Bay FL
« Reply #7 on: December 15, 2011, 11:36:19 PM »
Everything you needed to know about oil filters and some.
http://www.calsci.com/motorcycleinfo/FilterStudy.html
Valkyrie ~ "chooser of the slain"
RP#62
Gilbert, AZ
« Reply #8 on: December 16, 2011, 04:30:29 AM »
Make you feel good.
Little benefit.
Ricky, you need to get one of these:
http://kalecoauto.com/index.php?main_page=product_info&cPath=1&products_id=8
-RP
« Reply #9 on: December 16, 2011, 07:55:56 AM »
Oil filters are of little benefit ??  Humm, interesting..
I do have quite a number of old engines that have run fine for 50+ years without filters, but, things are done to compensate..
As far as Fram filters are concerned.. My family has used them since they were first made.. Never had an issue and we installed a several a day for the 50+ years I was around the shop.. I've seen other brands have issues though..
« Reply #10 on: December 17, 2011, 09:14:23 AM »
I use Pure1 PL14459 same size as ST3593A.
filter test shows it is good down to 12 microns, most wear is caused by particulate 10 microns and smaller. This is the closest one can get without using a by-pass filter system. These facts are why Rick-D is partially right.
SAE reports indicate not changing the oil filter too often and this applies to air filters also actually increases the filtration capabilites of the filter media.
Chrylser has recomended every other oil change to replace the filter since the '70s.
dipstick
« Reply #11 on: December 18, 2011, 02:30:13 PM »
WIX
Farther
Quimper Peninsula, WA
« Reply #12 on: December 18, 2011, 02:43:11 PM »
Honda automotive filter purchased by the six-pac.  http://www.handa-accessories.com/6packa01lrg.jpg
~Farther
The Anvil
Derry, NH
« Reply #13 on: December 18, 2011, 04:34:05 PM »
You can fit the full 4 quarts in a Valk without resorting to a larger filter. Not that there's anything wrong with using one as long as it's a quality filter, but that .10 quart is not going to cause any problems.
PSUbag
Huntingdon, Pa.
« Reply #14 on: December 18, 2011, 08:53:41 PM »
I've been putting the full gallon in mine for years, but I also lean the bike to the right after it's done draining straight up, just to get the rest out.
« Reply #15 on: December 19, 2011, 03:58:42 AM »
Yep, I certainly agree with that.. If the oil is drained, really drained, 4 qts is a tad short.. I lean it right and raise the front..
