February 03, 2026, 06:47:25 PM *
Author Topic: New Grips...  (Read 3944 times)
YoungPUP
Valparaiso, In
« on: December 18, 2011, 09:04:48 AM »
And the throttle sleeve too!!!
Came out of work friday and found the end of my right grip smashed to bits  laying next to the bike. Whoever got it smashed the chrome  cap and broke the end off of the throttle tube. Am trying to decide between replacing the stock bits( they work fine for me) or going aftermarket.  Any suggestions?
99 STD (Under construction)
Farther
Quimper Peninsula, WA
« Reply #1 on: December 18, 2011, 09:13:45 AM »
Stock is way cheaper and works just fine.  I think most after market are larger in diameter and with the Kurys you have many options as to chrome, black and the throttle assists.
~Farther
RUDE DOG - Steelers
New Jersey - VRCC # 3966
« Reply #2 on: December 18, 2011, 09:17:33 AM »
Go aftermarket then you have unlimited options and you wont need that specialty plastic sleeve anymore.  You just have to grind open the housing on the throttle side some.
« Last Edit: December 18, 2011, 09:19:45 AM by STEELERS - Rude Dog » Logged
« Reply #3 on: December 18, 2011, 09:49:14 AM »
Most of us who use the Kuyrakyn Iso grips, buy the longer 6 1/2 (or 1/4)" grips specific to the Valkyrie (part # 6190), and those do not come with a new throttle sleeve.... you reuse the Honda throttle sleeve.  The shorter universal grips may come with a new sleeve, I don't know.
http://www.kuryakyn.com/Products/3798/ISO-Grips
http://www.kuryakyn.com/documents/installation/6190-21MC-0311.pdf
So if your throttle sleeve is damaged beyond reuse, you will need another one, and may be stuck buying a whole Honda grip kit to get one (I do not know for sure on the Honda grips). But it seems to me if only a little of the sleeve is broken down near the end, it may still work OK with new grips if you ensure no glue gets between the new grips and the handlebar below the sleeve.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #4 on: December 18, 2011, 11:36:12 AM »
The only way to get an OEM throttle sleeve is to buy the OEM grip -- it's not available separately from Honda.  The stock right grip with throttle sleeve is about $30, if I recall correctly.
There are tons of grip options, especially at www.jpcycles.com  Don't limit yourself to those that only fit Valkyries or even those listed for "metric" bikes.  Finding a throttle sleeve is a bit trickier, but those listed for Honda Shadows (Spirit, Ace, Sabre) 750cc and larger work.
I just mounted these because of a similar problem to yours: http://www.jpcycles.com/product/ZZ50014 They come with the throttle sleeve.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
mario
NW Houston, TX
« Reply #5 on: December 18, 2011, 11:46:10 AM »
i have these on my sabre and valk.  they're a bit fatter but comfy for me.  i like them better than the kury iso's that i had.
good company, too, and i think they come with a sleeve if i'm remembering correctly.
http://www.coolsac.com/categories/Grips/
Mario
01 Valkyrie Standard (sold)
12 Suzuki V-Strom 1000
« Reply #6 on: December 18, 2011, 02:42:12 PM »
I like my Kury grips and they don't use that threaded part on the end of the sleeve.  I have small hands and the OEM grips still feel too small to me.
I'd use it as an excuse to go with better grips.
« Reply #7 on: December 18, 2011, 03:12:04 PM »
Most aftermarket grips turn to crap after a time.  Mostly from sun, rain and sweat.
Stock grips on the other hand are a perfect fit, no additional work required.
« Reply #8 on: December 18, 2011, 03:44:35 PM »
I'm not certain where Ricky gets his information.  I have over 150 thousand miles on my Kury grips and they're fine.
I guess perfect fit depends on what you like, but he'd already lost me with his BS statement on "turn to crap".  Wink
Valkpilot
Corinth, Texas
« Reply #9 on: December 18, 2011, 03:47:51 PM »
Nonsense.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Valkpilot
Corinth, Texas
« Reply #10 on: December 18, 2011, 03:50:56 PM »
The aftermarket grips referenced in the link I posted above are a perfect fit and no additional work was required, i.e., they installed exactly as stock grips are installed.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
The Anvil
Derry, NH
« Reply #11 on: December 18, 2011, 04:31:49 PM »
Probably the same place where you'll find un-paired socks and my apex bit; the outer limits.
« Reply #12 on: December 19, 2011, 07:07:45 AM »
Yep!
Same place where aftermarket is considered better.
Ignorance is not limited to the simply biased comments
and,,, reading opinion as being fact
is the realm of the incredibly arrogant.  (or incredibly stupid)
« Last Edit: December 19, 2011, 10:12:48 AM by Ricky-D » Logged
PharmBoy
Lawton, Ok
« Reply #13 on: December 19, 2011, 09:12:26 AM »
Go with what feels and looks good to you.  Personally, I like the Kury grips because they are longer and give you the option of going with the ISO®-Throttle Boss™ or the Contoured ISO®-Throttle Boss which vastly reduces that right arm fatigue on long trips.  Like I said, it's your bike.  Make it like you want it...Jim Smiley
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
Westsider
Fort Worth TX.
« Reply #14 on: December 19, 2011, 09:15:12 AM »
WHT??   W.T.H.   Was   Is up with that?     I like the stock grips..   will change anything else over to them...jmho and all that ... my .02 and would question if its worth that  just my  .02  but worth way more...... Grin Grin
« Last Edit: December 19, 2011, 09:25:18 AM by Westsider » Logged
The Anvil
Derry, NH
« Reply #15 on: December 19, 2011, 03:30:44 PM »
Yep!
Actually I'm on record as preferring stock grips (I have stock grips on my Valk and a virtually brandy-new pair of iso-grips in the package that I installed and didn't really care for). But I know lots of iso-grip users who like them and have lots of years on them. You're the one making unsubstantiated claims that aftermarket grips "fall apart".  Just admit it; you're talking out of your ass. It's not a big deal because we're used to it.
« Reply #16 on: December 20, 2011, 08:05:59 AM »
It's difficult to understand how profanity (and personal attack) is tolerated on this forum, but that, notwithstanding, I can only surmise that:
Cowardly equivocation is surely the most formidable weapon of the impotent eunuchs of which belonging to and referred to as "we're".
Get a grip!
Oh yeah, Merry Christmas to one and all.
Farther
« Reply #17 on: December 20, 2011, 09:29:49 AM »
To me answering a person's question in a condescending fashion without really providing any useful information is a passive aggressive personal attack.  Being passive aggressive is still a personal attack.
~Farther
« Reply #18 on: December 20, 2011, 09:39:38 AM »
Get whatever you like, but I guarantee you Kury ISO grips will outlast OE (or any full foam) grips, by years.   The sun/weather damage to the foam does not happen to the Kurys.
John U.
Southern Delaware
« Reply #19 on: December 20, 2011, 03:36:44 PM »
Mario, I have been considering a set of Sac grips but I read something on another site that questioned whether Sac grips would fit a Valkyrie. Did you need to use a specific model of grip? Any fitment problems? They appear fatter than stock grips which is what I want but I'm curious if a Throttle Rocker will fit.
Thanks for the link and any insight you can offer.
sugerbear
wentzville mo
« Reply #20 on: December 20, 2011, 04:16:45 PM »
i have some like this http://www.coolsac.com/plain-black-leather/ on mine.
nice, but wanted something larger. slip on's were advised here, bought a set (about $9) and they work really well. there foam but cheap and easy to replace.
The Anvil
Derry, NH
« Reply #21 on: December 20, 2011, 04:22:28 PM »
Because the erroneous (and often downright DANGEROUS) "information" you post puts it in perspective. My "personal attacks" and "profanity" (ass is profanity, really??) aren't going to get some poor bastard killed.
« Reply #22 on: December 20, 2011, 04:43:53 PM »
Wow, Anvil and Ricky D going at it.  This could be epic!  Shocked  Hey, I love ya both, so may the best man win.   cooldude  Hoser
Fritz The Cat
« Reply #23 on: December 21, 2011, 04:07:47 AM »
I had a set of Kury grips that were pure unadulterated garbage. They left a black smut deposit on my hands the whole time I had them. when the chrome started flaking off, I had had enough. Off they came and I swore I'd never buy another Kury product again. Your mileage may vary.
My absolute favorite grips of all time are these -
http://midwestcyclepro.com/mcp/index.php?main_page=product_info&cPath=61&products_id=395
They're perfect in every way except one, they don't make a set that fits on the Valk.  :'(
rangernight
New Orleans, LA
« Reply #24 on: December 21, 2011, 05:13:01 AM »
I have a set of ISO'S, yes they do leave a black smuge on your hands when they sweat, however I still like the look and comfort with the boss attached.  I have had them for over 10 years and the chrome is starting to wear thru, can see the copper plate in some area's.
Dirty Dave
Montreal, Canada
« Reply #25 on: December 21, 2011, 07:35:02 AM »
I found that the stock grips bugged my hands even wearing gloves which I do whenever riding. I prefer having the air spaces the Kurys provide. Don't like that Kury doesn't sell the rubber inserts for the grips separately 'cause they do look ratty on my Valk after 9 years. Just MHO.
It's weird being the same age as old people
« Reply #26 on: December 21, 2011, 01:30:42 PM »
Had my kury's for 9 years now and look like new. 68k, I think  Embarrassed on the odo. I wear fingerless gloves and never clean my grips.
Westsider
Fort Worth TX.
« Reply #27 on: December 21, 2011, 03:53:13 PM »
Find out who it was at work, and take the cost of at least stock grips to them... Angry ..
?? was it hit by a car or what ??
YoungPUP
Valparaiso, In
« Reply #28 on: December 21, 2011, 04:37:27 PM »
Wish I could find out who it was, but I start my day at a truck yard, and we have to park outside the fence in the customer area. so unfortunately that leaves it open to a few dozen people that could've doored my bike. What kills me is thats a million dollar hit. missed the mirror, but got the end of my firkin grip.... Angry
RonW
Newport Beach
« Reply #29 on: December 21, 2011, 09:07:45 PM »
is that the reason for spike grips.
2000 Valkyrie Tourer
