February 03, 2026, 06:40:46 PM *
Author Topic: Prolift Need Help  (Read 1464 times)
lawdog150
Leitchfield, Ky
« on: December 20, 2011, 02:27:36 PM »
I just installed the prolift jack adapter on my valkyrie. it is under the kick stand and nothing under the front. Do I need to put a piece of 2x4 or something else under the front or will it be fine?  Don't want to screw up anything. It looks to me like the bottom of the adapter is lower than the bottom of the motor. ???
« Last Edit: December 20, 2011, 02:32:35 PM by lawdog150 » Logged
frosty
« Reply #1 on: December 20, 2011, 04:37:31 PM »
One arm of you jack goes up to the btm. of adapter. The other arm to btm. of motor. Then raise your jack on up.  If going to leave your Valk raised for the winter lock your jack into position and may want to use ratchet straps from bike to jack on each side.
frosty
« Reply #2 on: December 20, 2011, 04:40:45 PM »
Heres the add which shows a pic. of the adapter on jack arm. The other jack arm is up to motor btm. Very steady and secure.
http://www.ebay.com/itm/VALKYRIE-LIFT-JACK-ADAPTER-STURDIEST-STAYS-BIKE-/170736431271?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item27c0af30a7
donaldcc
Palm Desert, CA
« Reply #3 on: December 20, 2011, 05:40:03 PM »
  if taking off wheels or anything that might make it a bit more unstable, i like jack stands under the front crash guard also.
« Last Edit: December 20, 2011, 05:42:07 PM by donaldcc » Logged
Don
lawdog150
Leitchfield, Ky
« Reply #4 on: December 20, 2011, 09:36:13 PM »
This is the best site I know of. You guys have the answer to each question. Thanks police
