February 03, 2026, 08:24:25 PM
U Joint Boot Question
Topic: U Joint Boot Question (Read 1590 times)
Jruby38
Oxford Mass.
December 24, 2011, 06:29:35 AM »
I install a new U joint and used my old boot. I see the back is on good but I have a little gap on the front by the engine output. Does the front fit flush to the block? Any pics, I do not have any way of comparing to another Valk. I think a little silicone seal is in order to keep any water or dust out. Last U joint went 100k any still seems ok, so I won't be back in there soon.
Re: U Joint Boot Question
December 24, 2011, 06:35:46 AM »
When reusing the old boot, it forms a "fit" and if you have a gap, it needs to be rotated to find the old "fit" position. New ones are symetrical.
December 24, 2011, 08:42:11 AM »
There is a lip on the inside circumference of the boot that is meant to fit into the corresponding groove on the case.
For two reasons.
A better sealing and a better more secure retention of the boot in the proper position.
Jruby38
Oxford Mass.
December 24, 2011, 09:20:36 AM »
Does the boot shrink with age like me, and will a new one be longer?
