February 03, 2026, 08:29:57 PM *
Author Topic: oil cooler with magnacharger  (Read 1549 times)
rdunbar123
Pasadena, tx
« on: December 28, 2011, 12:05:32 PM »
long time, no post. I installed a magnacharger and after much help from this site worked out the airfilter problem(used Dreamaker solution) Jetting, and have been enjoying the ride. only two issues. one, I still would like  to get a dyna 3000 from somewhere if anyone is parting out a bike in order to install a pressure switch and retard at higher boost. right now I add Lucas octane booster(real MMT) to everytank, expensive but  who cares. the  other only happened once when i was stuck in slow traffic this summer(houston is hot). cooled right back down when I started moving again. would an oil cooler help and if so where could i get one or has someone done this. One other item, maybe this will help someone. I was having a real problem  with cold weatherr starts, so much so I almost went back to stock for the winter. then on a hunch I installed a battery with 260CCA rather than the 190 on stock. The bike turned over and started tight away.
dreamaker
Harrison Township, Michigan
« Reply #1 on: December 28, 2011, 03:28:21 PM »
Check my pics on Photobucket and see the oil cooler I hade on my bike when I had the supercharger. You can get an idea, cool oil is always a good idea.
http://s625.photobucket.com/albums/tt332/dreamaker99/SuperCharger%20Setup/
« Reply #2 on: December 28, 2011, 03:28:47 PM »
Your best person to answer your questions is JeffK.    He is over in Florida now.
He is on here once in awhile but you could get him quicker on the Florida Board.
Jeff K
« Reply #3 on: December 28, 2011, 04:45:55 PM »
Here is my newest setup. I need to make some kind of cover for the ugly parts, but it works well.
Jeff K
« Reply #4 on: December 28, 2011, 04:47:50 PM »
I'm rarely on the Florida board. But Joanne is there a lot. But she never comes here, or the General board.
rdunbar123
Pasadena, tx
« Reply #5 on: December 28, 2011, 06:09:23 PM »
Jeff, I see the adapter, whose cooler did you use?
Jeff K
« Reply #6 on: December 28, 2011, 06:48:35 PM »
The oil cooler is a Earl's Performance Products 41008. The adapter fits but don't rely on the Oring between the adapter and the block. I made a gasket and glued it to the adapter.
rdunbar123
Pasadena, tx
« Reply #7 on: December 29, 2011, 02:34:31 AM »
Without you guys I would never have got the unit running right
« Reply #8 on: December 29, 2011, 11:41:52 AM »
Check with Mike Terry at the link below, he may have a Dyna 3000.
http://www.valkyrieblingandmore.com/
