February 03, 2026, 08:30:30 PM *
Author Topic: Rear tire for front  (Read 1427 times)
Jruby38
Oxford Mass.
« on: December 29, 2011, 10:47:11 AM »
Any recomendations for a rear tire make and size to use on the front?  I have a new E3 radial on the back now and a getting worn E3 on the front.  I am not pleased with the E3 front, it had an out of round condition from new and I want to replace it.  Can I use a 130/17 instead of a 150/17 on the front?
« Reply #1 on: December 29, 2011, 11:29:44 AM »
Sure, and many do, with the aim to getting more miles out of the tire.
« Reply #2 on: December 29, 2011, 12:05:01 PM »
search is your friend, don't be afraid.  cooldude  has been adressed many times
I use a Contigo rear on the front with an E3 on the rear.
scroll down was posted a few days ago.
PhredValk
Edmonton, Alberta, Canada
« Reply #3 on: December 29, 2011, 12:25:14 PM »
Brand is up to you, you can go radial or bias ply. Remember that the size will affect the speedometer as it registers from the front wheel.
These figures are from a calculator, and may not reflect actual manufactured tire dimensions.
Stock is    tread height (radius)
150/80-17 120mm
130/90-17 117mm
140/80-17 112mm
140/90-17 126mm
160/70-17 112mm
150/70-17 105mm
150/80-17 120mm
150/90-17 135mm (may not fit, haven't tried it)
I have a D404 130/90-17 bias rear on front.
Fred.
« Last Edit: December 29, 2011, 01:18:04 PM by PhredValk » Logged
VRCCDS0237
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #4 on: December 29, 2011, 12:25:57 PM »
I used a 150/70/17 and it was a about  1 1/2 inches shorter than stock, making my speedo read fast.  It also lowered my front axel 3/4" making my pegs scrape sooner than I would like.
A 130/90/17 is closer to the correct height.
« Last Edit: December 29, 2011, 12:28:02 PM by Fudd » Logged
Save a horse, ride a Valkyrie
