March 28, 2026, 10:12:55 AM *
Author Topic: signature picture?  (Read 1030 times)
moreira72
VRCC# 33494
Clark, NJ. 07066
« on: January 01, 2012, 12:06:52 PM »
How do i add a signature picture.
I tried to add one, but it shows the link and not the picture on the bottom of my posts.
« Last Edit: January 01, 2012, 12:17:46 PM by moreira72 » Logged
« Reply #1 on: January 01, 2012, 12:17:01 PM »
I think if you type [ i m g ] your link [ / i m g ] with out the spaces it will work
moreira72
VRCC# 33494
Clark, NJ. 07066
« Reply #2 on: January 01, 2012, 12:21:55 PM »
Thanks Skinhead. It worked cooldude cooldude
doodleman
Canton, Illinois
« Reply #3 on: January 01, 2012, 01:15:43 PM »
Hey, nice bike. Would you mind getting a closeup of your wings on the forks. I'm trying to decide what kind to purchase for my 99 I/S and I wanted to see your brackets that holds the plexiglass on.
Fritz The Cat
« Reply #4 on: January 01, 2012, 01:24:15 PM »
Shameless test of mine.
moreira72
VRCC# 33494
Clark, NJ. 07066
« Reply #5 on: January 01, 2012, 02:22:55 PM »
Thanks, Just bought it this past August. The Air deflectors on the forks were already on the bike when i bought it, but i think they are Memphis Shades lowers. At least the brackets look like they are
There is a set on ebay right now with clear plastics.
http://www.ebay.com/itm/MEMPHIS-SHADES-LOWERS-VALKYRIE-VULCAN-MARAUDER-WARRIOR-/370573245819?hash=item5647e2fd7b&item=370573245819&pt=Motorcycles_Parts_Accessories&vxp=mtr
Mine are smoked. Here is a picture of mine
Let me know if you need more pictures
doodleman
Canton, Illinois
« Reply #6 on: January 01, 2012, 04:47:10 PM »
What kind of brackets did you use? Are they the ones on Memphis Shades Lowers for Valkyrie? I like the ones you have.....
moreira72
VRCC# 33494
Clark, NJ. 07066
« Reply #7 on: January 01, 2012, 05:13:15 PM »
They are the Memphis Lowers Brackets. I just reversed mounted them so the plastics don't stick out so much. On a standard or tourer you can mount them wide, but on an Interstate the plastics touch the Pods when you turn all they way to right or left. Not much, but they do touch. You can run them like mine or cut 1/2 inch off the width of the plastics.
doodleman
Canton, Illinois
« Reply #8 on: January 01, 2012, 05:20:03 PM »
Ok thanks for the info
moreira72
VRCC# 33494
Clark, NJ. 07066
« Reply #9 on: January 01, 2012, 05:32:55 PM »
doodleman:
here are a couple of pictures of the set up when i boiught the bike.
PO had it set up as a Supervalk
But like i said the plastics touched the pods when turning the handlebars. So i had to mount them inside the forks and higher near the fairing so they don't touch the Pods when turning
« Last Edit: January 01, 2012, 05:35:37 PM by moreira72 » Logged
PhredValk
Edmonton, Alberta, Canada
« Reply #10 on: January 01, 2012, 08:50:23 PM »
How do they work re: cutting the wind from under the faring? I like the look of that way better than the Baker Airwings. And they won't crack the pods.
In the fine print in Description, it says mounting hardware only, plastics sold separately.
Fred.
VRCCDS0237
