August 21, 2025, 08:41:27 AM *
Author Topic: Factory Paint Codes  (Read 1590 times)
daTank
Roseville, MI
« on: January 02, 2012, 02:51:10 PM »
I have a 98 Standard that the tank has a few dings init .  The g uy I took it to, he was referred by MI Chrome, needs the factory paint codes to match up the colors.  I can't find the dam things anywhere.  I looked on the frame by the VIN, I looked under the seat, I even looked in the Clymer to see if they would tell me.  I cayen't find em anywhere!!
My girl is Yellow and white.  I 'think' its the stock colors.....The tank has pinstriping in between the colors....
VRCC # 33739
MP
North Dakota
« Reply #1 on: January 02, 2012, 03:14:34 PM »
Look for a sticker on the frame under the LEFT side cover.
MP
"Ridin' with Cycho"
daTank
Roseville, MI
« Reply #2 on: January 02, 2012, 03:40:18 PM »
Ok....there are two codes y146 and y14??  the bottom number has been scraped from the side cover....arrghhh!!
VRCC # 33739
MP
North Dakota
« Reply #3 on: January 02, 2012, 03:53:59 PM »
Go here:   http://www.valkyrienorway.com/COLORS.html
Says Y146 and Y137M
For paint from Colorrite:   http://www.colorrite.com/matrix-colors.cfm?CFID=1768029&CFTOKEN=63324718
MP
"Ridin' with Cycho"
daTank
Roseville, MI
« Reply #4 on: January 02, 2012, 04:02:11 PM »
Thanks MP!!  It doesn't look like a Y137M but I'm gonna go with it anyway!!  LOL
VRCC # 33739
indybobm
Franklin, Indiana VRCC # 5258
« Reply #5 on: January 03, 2012, 08:44:08 AM »
This brings up a question I asked last year but did not get answered. Did the factory use Base Coat/Clear Coat or single stage paint?
« Last Edit: January 03, 2012, 09:23:37 AM by indybobm » Logged
So many roads, so little time
VRCC # 5258
« Reply #6 on: January 03, 2012, 12:42:54 PM »
I think you'll find that answer on colorite. My Black/cream ACE Tourer bags need a colored base cost to come up to match the factory job.
If you are talking basic primer, then I don't know, other than EVERY paint job needs a primer, since primer adhears to a clean metal better than a show coat does.
Davet261
« Reply #7 on: January 03, 2012, 02:03:08 PM »
I have posted that answer on here before.  I worked for the company (TKS Tai-Ki-Sha) for 15 years which I was laid off from 2 years ago, that built the paint shop in the Valkyrie Assembly plant in Marysville, OH.  They used E-Coat, Primer Coat, Base Coat 1, Base Coat 2, Top Coat 1, Top Coat 2, Clear Coat 1, Clear Coat 2 so there are 8 coats of paint on the Valk, 10 coats if tutone......
