Been a while since I've had time to post here, I missed hanging out and reading up on all the great info & stories this site continues to dole out.
Last Feb I purchased a 98 two tone ct with 17k on her. She's in great shape, had only two other owners, a service man (air force I believe) bought her new, then the second owner from him, then to me.
As I said, she's in great shape, mechanically and paint wise, but the problems I didn't see when I got her, were caused by the locality of the second owner who resides on Long Island, NY.
Seems he would ride her and put her away wet, covering her with a tarp ( which I don’t get, cause he had a garage) holding in all the salt air residue to get baked into all the nooks and crannies.
All the major parts are in excellent shape, but the things that a giving me headaches are the small nuts & bolts and small chrome parts. I could only get three of the four front fender bolts out. After snapping a easy-out in the 4th bolt, I had to drill out the head and could only get the fender off after I took the front end completely apart. That’s ok, was gonna do it anyways.
I wasn’t planning on taking the water pump cover off till I looked at the bolts (rusty and corroded) and saw the cover was in need of some loving. I’ve painted my other’s black and they still look good after a season, so I started removing the bolts. Got three off without much problem, but the 4th, the bottom left, had welded itself to the pump. Broke the bolt and broke another easy out (Brand New Snap-on).
In the picture, you can see the easy out, which is hardened steel and I can’t drill it. It won’t budge with vise-grips and I’m afraid heat may warp the pump body.
New one is $150.00 and didn’t find any used on e-bay.
I’m wondering if I could drill it out from the back side (two bolts go through the pump and screw into the block and two just screw into the pump body, this is one of the latter) and use a nut and bolt?
Any ideas? Any one got a water pump for sale?
