August 21, 2025, 08:45:08 AM
Rear drive gear oil
Topic: Rear drive gear oil (Read 886 times)
Jruby38
Oxford Mass.
Rear drive gear oil
January 03, 2012, 08:11:19 AM »
Is anyone using 75/140 synthetic? Would the rear end run cooler with it?
Re: Rear drive gear oil
January 03, 2012, 08:19:11 AM »
Most all reports dealing with synthetic lubricants report cooler running temperatures due to the oil.
So you ought to see a change in operating temperature.
To what extent remains to be observed in your particular application.
9Ball
January 03, 2012, 10:03:39 AM »
your better choice is 75W90....the one you mentioned is not the recommended weight (80W) and is a bit too heavy for this application.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
=> InZane XXV
