January 28, 2026, 03:24:52 PM
viking air horns?
Topic: viking air horns? (Read 3108 times)
KCvalk
Alexandria VA
viking air horns?
May 08, 2009, 09:36:34 AM »
anyone using viking air horns instead of factory buzzer?
can these be connected to the factory horn button or do i need
a totally different push button to use these
thanks
the armor of the Valkyries "sheds a strange flickering light, which flashes up over the northern skies" making the aurora.
Joe Hummer
Arnold, MO
Re: viking air horns?
May 08, 2009, 10:12:52 AM »
Follow the advice here:
http://www.rattlebars.com/mtz/hornrelay.html
You can use the same button, just make sure you put in the relay.
Joe
1999 Valkyrie Interstate
KCvalk
Alexandria VA
May 08, 2009, 10:24:46 AM »
great thanks just the info i needed
Relax
Power & elegance...just like the Valk
Oslo, Norway
May 08, 2009, 10:43:56 AM »
I just put on the Stebel air horn w/ reley ete etc.. Wiorkd all right,,,but I had actually expected a loader sound ???
f-Stop
'98 Standard named Hildr
Driftwood, Texas
May 09, 2009, 08:59:52 PM »
I replaced the factory buzzer with these Rivco horns. Comes with everyting you need to use the stock switch...helps prevent CPLDS (Cell Phone Lane Drift Syndrome).
Windjammer
Danny Jones/Villa Park, IL. West Burbs of Chicago
Villa Park, IL
May 10, 2009, 11:44:44 AM »
While the air horns are OK? Check out BigBF's quad horns That will get your attention NOW! Plus they are hidden.
