February 03, 2026, 11:52:07 PM *
Author Topic: Radiator hose frustration  (Read 2265 times)
CISE
« on: January 07, 2012, 09:27:47 AM »
Good afternoon all, I have a question and probably a problem, and would like some non-pyschiatric help.
I have just installed a new upper rad hose on my 99 IS and it now has a kink/fold in the hose, just where it bends around teh frame to the radiator.
Will this kink/fold work out with antifreeze and pressure in the system or do I have to remove it and reinstall it?
Thanks.
olddog1946
Moses Lake, Wa
« Reply #1 on: January 07, 2012, 09:34:39 AM »
Your best bet would be to loosen the hose clamps and turn the hose a little til the crimp disappears.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #2 on: January 07, 2012, 02:19:58 PM »
Could restrict coolant flow. I'd fix it right away.
My rides:
CISE
« Reply #3 on: January 08, 2012, 07:13:05 AM »
Here is a photo of teh crimp, turning the hose does not seem to make a difference.
My next option is to shorten the hose by about an inch. Thoughts?
« Last Edit: January 08, 2012, 04:06:35 PM by Willow » Logged
BonS
Blue Springs, MO
« Reply #4 on: January 08, 2012, 07:45:33 AM »
Is this an OEM 1-1/8" pre-formed hose?
« Reply #5 on: January 08, 2012, 09:15:22 AM »
Yep, good question.
Doesn't look correct and I don't think shortening it will help out much.
Could use an internal spring to open it up.
CISE
« Reply #6 on: January 08, 2012, 10:09:41 AM »
Yes it is an EOM hose from HDL.
There are days when I really like working on my bike and then there are days when I can understand why a member took a hammer to his.
Fritz The Cat
« Reply #7 on: January 08, 2012, 10:16:50 AM »
It's supposed to be pre formed, no kink necessary. looks like they sent you the wrong hose.
BonS
Blue Springs, MO
« Reply #8 on: January 08, 2012, 11:26:15 AM »
Could it be turned backward? You know, radiator end on engine and engine side on radiator?
Madmike
Campbell River BC, Canada
« Reply #9 on: January 08, 2012, 11:45:05 AM »
something not right there, if you run it that way it will most likely overheat the engine, end for end or twist maybe?????  If you lay this one beside the old hose does it even look close to the same shape??
Tropic traveler
Silver Springs, Florida
« Reply #10 on: January 08, 2012, 02:13:07 PM »
+1, it's easy to do! Shocked
'13 F6B red for Kim
3W-lonerider
Shippensburg Pa
« Reply #11 on: January 08, 2012, 02:13:43 PM »
if that is the oem hose..i'd say you put it on backward...the 90 degree bend needs to go to the thermostat housing and the 45 degree bend needs to go to the radiator..
olddog1946
Moses Lake, Wa
« Reply #12 on: January 08, 2012, 03:17:34 PM »
I just dug out my new hoses  for my std.. upper hose is 19116-MZ0-000 and the lower hose is 19115-MZO-000. I think you've got the wrong hose, if I turn mine backward, the kink is just above the thermostat. The lower hose put up top would kink just like that.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
CISE
« Reply #13 on: January 09, 2012, 03:33:54 AM »
I believe that is the issue.
I will pull it off and turn it around tonight.
I just love being a dumb a$$ user
« Reply #14 on: January 09, 2012, 06:29:50 AM »
No such thing.  That's why you posted your question here where there are others that have either done it, or can help you through it.
I hope it being on backwards is really your problem, that way it will be fixed!
Only Dumb question is one that you don't ask.
Hay  Cool
olddog1946
Moses Lake, Wa
« Reply #15 on: January 09, 2012, 09:42:12 AM »
Being a Dumb Arse is how I learn, most of the time...occasionally I will take advice from others that have gone before and done their own dumb arse thing. lol
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
John U.
Southern Delaware
« Reply #16 on: January 09, 2012, 10:39:13 AM »
If only I had a dollar for every time I've done something incorrect that seems dumb to me after I've done it, then found out what I should have done instead.
I could be vacationing in the Keys with all those bucks.  crazy2
olddog1946
Moses Lake, Wa
« Reply #17 on: January 10, 2012, 08:11:58 PM »
Well, we are all waiting to hear what the result was..
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
CISE
« Reply #18 on: January 11, 2012, 03:35:17 AM »
Result:
Removed hose and turned it around. Still kinked.
Shortened hose - still kinked (regardless of which way it was installed).
Said many unpleasant words - Went to NAPA (I get a discount there) and bought a generic flexible hose. No kink.
Now to get the air cleaner back on.
The best part - the hose did not need to be replaced. About 3 years ago I replaced the leaking stock hose with a generic flexible because I could not get a stcok hose in the time frame I needed it in.. Decided since I was desmogging the bike I may as well put a new correct hose on it.
I know I know - "If it ain't broke don't fix it" -  I may have to tatto that to teh back of my right hand.
But thanks for all the help guys!!!!
