February 03, 2026, 11:52:04 PM *
Author Topic: A petcock issue I've not had before  (Read 2030 times)
RainMaker
Arlington, TX
« on: January 07, 2012, 06:58:43 PM »
Took off the tank and could not pull a vacuum - just gas - out of the vacuum tube.  Figured a bad diaphragm.  So rebuilt the petcock with a K&L kit with new spring, diaphragms.  Tied it back together in the correct format (spring, disc, big diaphragm, metal connector, fuel diaphragm) and vacuum holds great.  Put gas in the tank, put a clear tube on the gas outflow and no gas flowing at off.  Turned to on and no gas.  Pulled a vacuum and - no gas.  Switched to reserve and no gas with vacuum.  It's like the fuel diaphragm is not opening.  Tank has about 2 gallons in it.  Screen is clean.
Ideas?
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
MP
North Dakota
« Reply #1 on: January 07, 2012, 07:05:59 PM »
you can pull a vac on the line, and then blow into the inlet into the petcock to see if it is opening up.
"Ridin' with Cycho"
RainMaker
Arlington, TX
« Reply #2 on: January 07, 2012, 07:28:06 PM »
pulled the petcock off and looked down the outlet and the diaphragm is opening when I put vacuum on it.  Put the petcock back  on and on reserve, I finally got it to flow but there were bubbles in the flow.  Turned it to ON and tilted the tank back - no flow.  Turned it back to reserve and it doesn't flow with vacuum.
I think the petcock itself may be bad, i.e, ball sticking.
2005 BMW R1200 GS
1972 CB500K1
Valkpilot
What does the data say?
Corinth, Texas
« Reply #3 on: January 07, 2012, 10:14:16 PM »
Are you getting positive feedback, i.e. is it clicking into place, when you move the selector from one position to another?
If not, I agree that the ball & spring part of the mechanism might not be working.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
RainMaker
Arlington, TX
« Reply #4 on: January 08, 2012, 05:24:50 AM »
I pulled it apart again, reset everything with a new kit and now it works.  Go figure.  The first kit was bad.  Appears the fuel diaphragm may have been the wrong one - looks different than the second one and the original.
Problem solved - now have to get the carbs clean out.  This thing runs horribly.
2005 BMW R1200 GS
1972 CB500K1
Westsider
Fort Worth TX.
« Reply #5 on: January 08, 2012, 06:02:01 AM »
Did you say problems with a stock petcock, oh, ah ,er,   ever mind.   Evil Evil
Valkpilot
Corinth, Texas
« Reply #6 on: January 08, 2012, 06:04:29 AM »
I'm curious.  Was the rebuild kit an OEM cover set kit or one of the others that only has the plastic parts?
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Disco
Republic of Texas
« Reply #7 on: January 08, 2012, 06:58:25 AM »
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
Valkpilot
Corinth, Texas
« Reply #8 on: January 08, 2012, 10:46:09 AM »
Silly me.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Disco
Republic of Texas
« Reply #9 on: January 08, 2012, 11:42:12 AM »
Sorry, Dave.  I forgot to put a smiley in there.
Here goes...   angel
78 CB550K
RainMaker
Arlington, TX
« Reply #10 on: January 08, 2012, 06:29:43 PM »
Hope you two are having a good time with this.  Wink
2005 BMW R1200 GS
1972 CB500K1
Valkpilot
Corinth, Texas
« Reply #11 on: January 08, 2012, 06:46:56 PM »
Well, we were, Captain Buzzkill. coolsmiley
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Disco
Republic of Texas
« Reply #12 on: January 08, 2012, 07:40:08 PM »
Neither one of us got to ride 429 miles today, so we've had to find fun somewhere else...   Grin
78 CB550K
« Reply #13 on: January 08, 2012, 08:00:50 PM »
Uh, that would be "MR. Buzzkill".
Hay <----  only couple hundred miles today...   angel
