February 03, 2026, 11:52:23 PM *
Author Topic: Pilot Screw Frozen  (Read 1648 times)
Red Diamond
Beaumont, Texas
« on: January 09, 2012, 05:37:50 AM »
Is it normal for the pilot screws to be frozen? I've tried to move mine on both the I/S and the Tourer and can't get them to go either way. I don't want to exert unusual pressure, looking for input from anyone who has adjusted them and what did you do, if they were frozen. Thanks for any help.
JC
The Beast
Franklin, TN
« Reply #1 on: January 09, 2012, 05:58:08 AM »
I'd hit them with some WD40 or Liquid Wrench and let it set for a short time first. They will tend to bind up a bit since they haven't been moved in a while. You might want to pull them out for inspection just to be on the safe side.
When I rebuilt my carbs a year or so back, I found the #5 pilot screw appeared to have been burned. It was really tough to remove, and the spring, washer, and o-ring were black and crispy. The screw was okay, but it took a while to get the hole cleaned out. I used a spring and o-ring from an old CB650 carb in the junk pile, and got lucky when a mech at the stealer just happened to have a washer in his collection.
« Reply #2 on: January 09, 2012, 06:31:57 AM »
Did you get the motion-pro socket that is made for those pilot screws?
Or are you trying to use that geared tool to do it?
If you use the socket with a thumb wheel, it will make it a lot easier to get them loose.
Here is the socket:  http://www.motionpro.com/motorcycle/partno/08-0242
« Reply #3 on: January 09, 2012, 08:44:32 AM »
It happens every now and again.. What is the problem you're having ?? Are you afraid/concerned about using too much pressure to turn the screw or has the 'D' now become an 'O' ?? A small disk on a Dremel type tool may be needed to slot the screw to be removed with a screwdriver.. The disk will cut into the casting but shouldn't cause a problem as long as isn't cut too deep..
I slot them and add a dab of never seize to threads when re-installing them..
I don't have an issue with using heat to try and loosen them as long as I'm sure I'm not going to burn the house down..
Red Diamond
Beaumont, Texas
« Reply #4 on: January 09, 2012, 11:27:28 AM »
No, it has not become an "O" Patrick, they just seem to frozen in place, I'll try a little more pressure.
Yep Ricky, that's the socket, I just received the whole shabang from Motion Pro a few days ago.
JetDriver
Columbus, OH
« Reply #5 on: January 09, 2012, 09:33:23 PM »
How do you become "sure"?  Seems like the learning curve would be a little steep! Evil Evil
« Reply #6 on: January 10, 2012, 06:26:23 AM »
Hehehe, how does one become sure ??, Hehehe..  Experience I guess.. I've not yet burned anything down, but, there have been a few exciting moments over the years!! I guess there right and wrong times and places to fire up a torch..
wild6
(Old enough to know better)
Vernon, NJ
« Reply #7 on: January 10, 2012, 12:39:23 PM »
Don't know if it'll help but I remember seeing this: http://www.valkyrieforum.com/bbs/index.php/topic,8485.msg65987.html#msg65987
