February 03, 2026, 11:52:01 PM *
Author Topic: smoke  (Read 1647 times)
zoltan57
Denver, Colorado
« on: January 11, 2012, 05:07:35 PM »
i just moved back to florida from colorado 2 weeks ago and when i start my bike up im getting white smoke coming from my right pipes...is it the altitude change?  i adjusted my idle to 800 rpms from 1000.. but the gas i was using was 85 octane in colorado and here they have 87 octane... any suggestions on this...maybe new plugs.. or put some seafoam in the tank .. thanks.... emrik
« Reply #1 on: January 11, 2012, 05:10:32 PM »
Florida is a lot more humid than Colorado. I'd guess you're steaming moisture out of the exhaust. It should go away as it warms up.
Dougs2000IS
Wisconsin
« Reply #2 on: January 11, 2012, 05:41:55 PM »
Drive it. Florida is warm. Im in wisconsin and will not see 50 for another two months.
2013 Victory Vision Arlen Ness
2000 Valk Interstate (sold)
1997 Ford F150
2006 Honda Civic Hybrid
Go Packers
« Reply #3 on: January 11, 2012, 06:12:45 PM »
Most all valks will puff a little white vapor on startup, esp on choke.
Now with choke off and warmed up, if you are still puffing vapor/smoke, you may want to look at things.
SANDMAN5
Mileage 65875
East TN
« Reply #4 on: January 11, 2012, 06:28:08 PM »
My brand new '03 smoked at start-up from the day I first started her with
0.4 miles until the day she went to Heaven and a little over 38,000. My
'98 has 61,000 and smokes a little bit at start-up.
« Last Edit: January 12, 2012, 09:38:43 AM by bashfulbob » Logged
« Reply #5 on: January 12, 2012, 09:13:54 AM »
White smoke = water vapour
Blue smoke = oil burning
Black smoke = unburnt fuel
« Reply #6 on: January 12, 2012, 03:08:39 PM »
Welcome back to the sunshine state.  Mine does that.....just like you discribed....especially when the dew point is high (the RH and temp being closer together).
zoltan57
Denver, Colorado
« Reply #7 on: January 12, 2012, 07:01:41 PM »
thank you for all your thoughts i will keep an eye on it.. the smoke color is white...
PhredValk
Edmonton, Alberta, Canada
« Reply #8 on: January 12, 2012, 11:10:35 PM »
Shouldn't be a problem. Mine does that when the humidity is up or the temp is down. So did my GL1100.
Fred.
VRCCDS0237
