February 03, 2026, 11:52:04 PM
Rear Drive problems
Topic: Rear Drive problems (Read 1361 times)
Jim McCarty
Rear Drive problems
January 13, 2012, 12:54:43 PM »
Are the final drive problems on the Valkyrie isolated to the Valk? I never hear of them on Goldwings, VtX, or Shadows.
Gotta be a good reason.
GOOSE
D.S. #: 1643
Southwest Virginia
Re: Rear Drive problems
January 13, 2012, 01:08:06 PM »
Jim....I've got two valks/one 1500 GW....The 1500 GW is like the valk as far as the rear goes......can have the same problems from lack of care/maintenance. The rears are not interchangeable, but the same problems exist. I don't know about VTX'S or Shadows. THe bottom line here is this...the valk/1500 gw rears will go forever (well-almost) if you perform the simple/easy maintenance on them about every 10-12 thousand miles. If you don't, well...they go down the tubes rather quickly without it. It's your choice.
Jim McCarty
January 13, 2012, 01:27:56 PM »
Thanks Goose. I've owned a couple of Valks, never did the rear spline maintenance myself. Had it done when I replaced tires.
Just don't ever hear of it with other Hondas, & was wondering why.
January 13, 2012, 01:44:36 PM »
Quote from: Jim McCarty on January 13, 2012, 01:27:56 PM
Seems like Goldwings would be just like Valkyries...
http://www.hrot.org/martino/goldwing/reartire/driveshaft.htm
http://www.hrot.org/martino/goldwing/reartire/tire4.htm
January 13, 2012, 02:38:13 PM »
I also have a Shadow ACE Tourer, 1100 shaft drive. No mention about the rear being a problem. But then most of the bikes are sitting less than 50K miles. Mines sitting close to 50K Km.
I happen to have a spare rear hub, u-joint and drive shaft, from a parted out bike. No signs of wear.
We have a couple of HSATF members who have over 100K miles on their T's.
PhredValk
Edmonton, Alberta, Canada
January 14, 2012, 03:15:55 AM »
When I had the dealer change the rear tire on my 1980 GL1100 wing, the splines were smeared with moly paste, so I think this is a standard practice on all shaft drive rear ends.
Fred.
VRCCDS0237
