February 04, 2026, 01:35:36 AM *
Author Topic: Mother's Powerball  (Read 2212 times)
RonW
Newport Beach
« on: January 15, 2012, 03:50:24 AM »
I've read earlier that MothersĀ® Powerball is great for polishing the wheels on a Valk. Any recommendations on what type of polish is the best to use on the wheels. Mines seem to have water spots. But after hand polishing the wheels, or at least the clear coat layer on the wheels, the watermarks are still there. I've been using clear coat polish. And another question, which is better .... the large ball (below left) or the 'mini ball'? As always, thanks in advance.
2000 Valkyrie Tourer
junior
new hampshire
« Reply #1 on: January 15, 2012, 04:10:57 AM »
the mini ball, it gets in behind the brake rotor without grabbing
« Reply #2 on: January 15, 2012, 04:38:02 AM »
Mother's polishing paste works fine.  Hoser
Thrud
2000 Valkyrie Interstate
« Reply #3 on: January 15, 2012, 06:01:23 AM »
Flitz polish is da bomb!  (http://www.flitz.com/p-16-flitz-polish-paste.aspx)  I use it all over my Interstate and it works great.  Does a great job on your wheels when used with the powerball.
Steve
PAVALKER
Pittsburgh, Pa
« Reply #4 on: January 15, 2012, 07:42:21 AM »
I had water stains, or some kind of stain, on my VTX wheels (2 years of neglect before I started really keeping up on them).  I used a soft green pot scrubber with Soft Scrub w/bleach to clean the wheels good, then a Brillo pad to smooth them out and finally Mother's Mini Power Ball and White Diamond... looked great.  Did the same with my Valk.  Now I just give them an annual Mini Power Ball touch up w/White Diamond in the Spring and maybe a touch up by hand in the Summer.
John
« Reply #5 on: January 15, 2012, 07:55:14 AM »
http://www.chromeworld.com/ProductDetails/ProductDetails.aspx?pid={c0acc547-a890-45e0-9e39-a5837a530064}&
The Mothers balls are pretty good for polishing, but for deep corrosion or stains hard cotton wheels work better.
« Reply #6 on: January 15, 2012, 11:20:04 AM »
want a mirror shine?
http://topoftheline.com/rolmetpolkit.html
http://topoftheline.com/rolapsupfinp.html
http://topoftheline.com/poal.html  they don't use foam for polishing metal, on the site foam is only used for paint polishing
Gear Jammer
Yeah,,,,,It's a HEMI
Magnolia, Texas
« Reply #7 on: January 15, 2012, 12:29:44 PM »
White Diamond is my choice
« Reply #8 on: January 15, 2012, 03:55:03 PM »
QUOTE
I've read earlier that MothersĀ® Powerball is great for polishing the wheels on a Valk. Any recommendations on what type of polish is the best to use on the wheels. Mines seem to have water spots. But after hand polishing the wheels, or at least the clear coat layer on the wheels, the watermarks are still there. I've been using clear coat polish. END QUOTE
You mention clearcoat on the wheels. What year is your Valk? Up to 2000, the wheels weren't clearcoated. 2001 and up had polished and coated wheels. I wasn't aware you could polish a coated wheel.
Sodbuster
« Reply #9 on: January 15, 2012, 04:49:51 PM »
Have you looked into the stuff they use to clean aluminum boat hulls ?? The cleaner removes ALL stains, etc. and turns the aluminum to a whitish color until you start polishing it. Click Here
VRCC # 30938
RonW
Newport Beach
« Reply #10 on: January 15, 2012, 05:08:55 PM »
2000 Tourer. It looks like there's some thin coating of some kind on the aluminum surface. If there isn't then the bare aluminum still is in relatively great shape.
no, I haven't tried Aluminator before, or even heard of it til now.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #11 on: January 15, 2012, 05:56:37 PM »
Mini Ball and White Diamond, or Magic Mix  Wink
States I Have Ridden In
junior
new hampshire
« Reply #12 on: January 16, 2012, 02:30:52 AM »
MMMMMMMMMMMMMM Magic Mix................you must be a trucker?
