April 28, 2026, 11:49:02 PM *
Author Topic: stock exhaust  (Read 2114 times)
mooserider
Blue Knights TX6, Ride with Pride
La Porte, Tx
« on: May 10, 2009, 09:53:40 AM »
Hi all
    I have a 1999 tourer and I really lOVE the sound of my factory exhaust, i'm not interested in changing it out. But the problem I have is that the end of the exhaust pipes do not extend past the saddle bags and while i'm in stop and go traffic or stopped at a red light I smell the exhaust fumes. It's coming out the pipe and rolling under the saddle bag and exiting at the front of the saddlebag. I verified that it is coming from under the saddlebags I do not have an exhaust leak around the engine.
 Does any one know if there is a replacement tip I can install that will extend the exhaust to the end of the saddlebag with out too much modification?
Thanks Keith
Ride with Pride
« Reply #1 on: May 10, 2009, 10:02:30 AM »
There's a weep hole on each pipe that you can see first thing in the morning
when you crank it up, before it stops smoking. Crank it up with the choke on,
and stand back and look, you should be able to see it right away... They point straight down,
and are right under you... might be coming from there...
I thought I had a picture, but my file called "choke" turns out to be this  Grin
mooserider
La Porte, Tx
« Reply #2 on: May 10, 2009, 10:11:37 AM »
LOL Thanks Mike I'll check it out
Keith
Ride with Pride
franco6
Houston, TX
« Reply #3 on: May 11, 2009, 06:48:14 AM »
 Smiley :-\Smokey, smelly exhaust,especialy when stoped at a light after warm up you have more to worry about then your exh. tips.Maybe, get acomplete tune-up to start w compression check. Anyway thats where I d start.enjoy Fred
Enjoy the ride!
