April 28, 2026, 10:46:23 PM *
Author Topic: white smoke  (Read 2626 times)
mooserider
Blue Knights TX6, Ride with Pride
La Porte, Tx
« on: May 10, 2009, 10:00:48 AM »
Hi all
   I have a 1999 tourer when I first start the bike in the morning I'm getting white smoke out the tail pipe. it's not a thick white smoke but it noticable and it continues until it warms up. It is smoke it's not condensation. Once the initial start up it doesn't do it again the rest of the day. I have just over 37,000 miles and it runs fine. My oil level as well as anti feeze level never changes.
   Any idea's what could be wrong? bad rings? or seals?
Thanks Keith
Ride with Pride
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: May 10, 2009, 10:55:27 AM »
How do you know it is not condensation? If you are right and it is smoke, just smell it. You can easily tell the difference between oil and antifreeze. You can also cover the exhaust tips with a clean, white cloth, Start it and run it for a couple minutes. Look at the cloth for oily residue.
mooserider
La Porte, Tx
« Reply #2 on: May 10, 2009, 11:08:19 AM »
Thanks for the tip, Condensation is mostly moisture, the smoke coming out my tail pipes is a cloud like if  I run it in the garage it will fill the garage with white smoke.
Ride with Pride
john
tyler texas
« Reply #3 on: May 10, 2009, 12:22:53 PM »
its from choke on cold engine ...    Shocked
give it a few seconds  ...
turn off choke ...unless you like blue exhaust headers    crazy2
and get on with your day    cooldude
vrcc # 19002
SANDMAN5
Mileage 65875
East TN
« Reply #4 on: May 10, 2009, 01:27:27 PM »
I'm on my 2nd Valk and they've both done that. I bought my '03 brand new and
it "puffed" a little white smoke at start up from the day I took it home until the
day it went to Motorcycle Heaven. She had 38,000 miles when she died. My '98
does it also. Nothing to worry about unless it starts to get considerabl worse, IMHO.
Lastdragon
03 Black Standard, Yukon America
Yukon, Oklahoma
« Reply #5 on: May 11, 2009, 08:35:07 AM »
When pulling into the garage and shutting down after the last ride of the day, turn the engine off, then lean the bike slightly to the right for a few seconds, then put the kickstand down and lean it back to rest on the stand.  What this does is drain most of the small amount of the oil in the left cylinders below the pistons which would slowly leak past the rings and end up on top of the pistons and cause the smoke upon start up.  The right hand cylinders drain naturally when the bike rest on the kickstand.  I have had two goldwings and the valkyrie and they all will smoke ocassionally out the left exhaust on start up (which is no big deal) but I find that this process eliminates the smoke.  Works for me.
Ronnie Evans
Yukon, America
Member #17151
mooserider
La Porte, Tx
« Reply #6 on: May 11, 2009, 01:29:47 PM »
Thanks Lastdragon i'll start doing that and thanks everyone for their responses
Keith
Ride with Pride
