November 23, 2025, 05:42:33 PM *
Author Topic: snap ring pliers?  (Read 2231 times)
fiddle mike
Nothing exceeds like excess.
Corpus Christi, TX
« on: January 21, 2012, 05:05:37 PM »
I need to rebuild the clutch master cylinder but don't own snap ring pliers.  I don't want to borrow from Auto Zone.  What do I need to know before I give Sears my money for a pair?
Thnx
FM
Dag
Country Rep. Norway
« Reply #1 on: January 21, 2012, 05:22:09 PM »
I bought this 5 pc set from Northern Tool. You dont need to know anything if you buy a set like this.
http://www.northerntool.com/shop/tools/product_200230374_200230374
GreenLantern57
Hail to the king baby!
Rock Hill, SC
« Reply #2 on: January 21, 2012, 05:23:15 PM »
get one with interchangeable tips.
Dag
Country Rep. Norway
« Reply #3 on: January 21, 2012, 05:25:29 PM »
That`s a good option  cooldude
Madmike
Campbell River BC, Canada
« Reply #4 on: January 21, 2012, 06:36:14 PM »
Thnx
FM
The multi tip ones can be finicky but if you haven't had a need up to this point in life then they should be adequate.  See what tips they give you - size and angle.  As with most tools you will get what you pay for, if you figure you will have subsequent needs and there is a choice in quality look for sturdiness of structure and build.  I started a job this year that supplies a tool kit at the workplace and bought an 8 or 10 piece set of inner and outer snap ring pliers but they were several hundred dollars - the multitips may not be as versatile but there is a cost trade off.
« Reply #5 on: January 21, 2012, 06:52:28 PM »
Mike: Clean up the cylinder and take it to Sears. Then you'll know it will fit when you get it home.
« Reply #6 on: January 21, 2012, 10:30:26 PM »
I have that 5 piece set likes Dag's from Northern and I love it......
I used to have an interchangeable set.   Seems like for some reason or another I'd wear em out.    Well that's what Sears told me.     I got tired of going back to Sears to see if they would warranty them.    It was worth the little extra $$$$$ I paid for them to not have to go to the Store for a replacement.   Besides that, never used them that much anyway.
I bought this set from Northern, I want to say 3 or 4 years ago, my rememberer has gone on the blink.    I know it has been a while back.   I got mine when they had their tools on sale, like 40% off or some damn #.
I just got a email from Northern that they have a sale of some kind till the end of January.
http://www.northerntool.com/shop/tools/NTESearch?storeId=6970&N=0&Ntk=All&Ntt=key+ring+pliers&Nty=1&D=key+ring+pliers&Ntx=mode+matchallpartial&Dx=mode+matchallpartial
« Last Edit: January 21, 2012, 10:35:32 PM by R J » Logged
« Reply #7 on: January 22, 2012, 06:50:21 AM »
I also have that five piece set. Neat thing with them is you can change the location of the pivot on the handle which switches them from expansion pliers to compression pliers. Kinda like getting a set of ten instead of five.
« Reply #8 on: January 22, 2012, 07:15:54 AM »
I bought a set that looks exactly like Dag's from Northern, from Harbor Freight. Here's the link and a pic:
http://www.harborfreight.com/5-piece-retaining-ring-pliers-set-610.html
 Pure junk.  They can not handle the force needed to move the ends on snap rings - every one of them, the tips bend.  Untempered or bad steel, whatever - but a complete waste of money - though the money isn't much.  So be advised - don't get them from Harbor Freight - they look exactly like Dag's picture, even the same color handles.  I have another one with interchangeable tips, don't know where I got it, but it has served me well for years.  I needed a really heavy duty one for compressing a really large snap ring inside Progressive's 416 shocks to replace the seals.  So I just welded some tempered steel tips onto a large set of pliars, then re-tempered the steel.  Here's a pic:
Yep, it's a Harbor Freight pliar.  Nice thing about it, it's cheap so I don't mind modifying it - not like quality expensive tools like Snap-On etc.
Anymore, most of the time if I need a special tool, I just make it.  Jigs, special purpose hydraulic presses, special-shape hand tools to get into tight places, etc.  It's most expedient for me to just make it to fit rather than to try to go buy a dedicated tool which might exist, but probably doesn't.
I'd suggest, if you don't have one already, get yourself a MIG welder and learn how to use it.  For this purpose, you will also need the ability to remove metal - angle grinder, Dremel, chop saw, belt and disc sanders, hand held drill and drill presses, and a lathe, all serve in this function for various size and shape cuts and levels of detail. Comes in really handy, to have the ability and equipment to make tools you need.  You'll find that expands the possible solutions at your disposal exponentially.
« Last Edit: January 22, 2012, 07:45:09 AM by MarkT » Logged
« Reply #9 on: January 22, 2012, 09:22:43 AM »
MarkT thanks for the heads up on the snap ring pliers. Dag also. I've got some H F tools that up to this point have served me well. My H F yellow lift comes to mind here. I think the chinese heat treating and metalurgy is a little or a lot behind ours-good old U S of A. cooldude Like i told my brother who is a retired mechanic -i'm not making a living with my tools. My tool purchase patterns would be way different if i was making a living with my tools.  coolsmiley RIDE SAFE.
da prez
Wilmot Wi
« Reply #10 on: January 24, 2012, 01:59:36 PM »
 One trick to removing snap rings is to use a small pinch and tap tne ring around a little to free it up.  If it is to deep to use a punch to turn it, tap on it with the punch.  A lot of times. the ring is rusted or corroded in .  I have all kinds of snap ring pliers, but prefer the fixed tip. My longest pair is about three feet.
                                                          da prez
