August 21, 2025, 06:10:58 AM *
Author Topic: Tank Badge Glue Removal  (Read 1455 times)
Old Geezer Richard
San Antonio , Tx
« on: January 24, 2012, 02:05:33 PM »
  Now that I took off my Tank Badges , I'm having a little trouble getting that old dried up glue left behind off ... I have tried the Goo-Be-Gone and it did not much do anything , but soak the old glue ... any suggestions , BECAUSE I have some pinstriping underneath where the badges were and I don't want to mess up my pinstriping if at all possible ... Thanks the Geezer crazy2
F6BANGER
Albuquerque NM
« Reply #1 on: January 24, 2012, 02:11:20 PM »
Hey Geezer,
I got a belt sander with some 80 grit that should do the trick.... 2funny
gimme a call
Grandpot
Fort Mill, South Carolina
« Reply #2 on: January 24, 2012, 02:26:01 PM »
Charcoal Lighter fluid works well on glue and road tar without damaging the paint.
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #3 on: January 24, 2012, 02:44:32 PM »
Spray it and let it soak in WD-40, heat it with a heatgun/blowdryer, re-spray with WD-40. Rub it off with your fingers
KSDragonRider
Salina, KS
« Reply #4 on: January 24, 2012, 04:15:03 PM »
friend that does vinyl work says common kitchen vegetable oil works for taking the sticky glue off. I have never used it myself, but it is easier on stuff than the other chemicals listed.
Dalen & Shay -> Salina, KS
VRCC Member #33950
YoungPUP
Valparaiso, In
« Reply #5 on: January 24, 2012, 06:00:38 PM »
3M General Purpose Adhesive Cleaner, P/n  08984, should be available at your local body/auto paint  supply house. BE CAUTIOUS AROUND PLASTIC WITH THIS!!!
99 STD (Under construction)
larswlvs
my littlest riding partner
Akron,Ohio
« Reply #6 on: January 24, 2012, 10:11:23 PM »
Mineral Spirits or Go-Jo hand cream which has MS in it..if using the Go-Jo just put it on and let it soak in.
Make sure you get the original and not the one with pumice in it.
If guns kill people where are mine hiding the bodies
Old Geezer Richard
San Antonio , Tx
« Reply #7 on: January 25, 2012, 06:36:20 AM »
 Hey Macdoesit , I took the Tank Badge off BECAUSE I want to have the words Valkyrie painted on instead because TO ME ITS LOOKS MUCH BETTER , instead of having that cheap metal ... Thanks the Geezer crazy2
