larswlvs
my littlest riding partner
Akron,Ohio
« on: January 25, 2012, 11:11:22 PM » |
On my bike carbs #3 and #4 are connected with hoses and a T fitting. My question is ...do these carbs have to be connected to each other and I cap off the T or can I get rid of the hoses and T and just cap off each carb.
  If guns kill people where are mine hiding the bodies
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #1 on: January 25, 2012, 11:32:35 PM » |
just capping off #'s 3 and 4 is not de-smoging. there is alot of other things that have to be done to complete the de-smog. look in shop talk, or use the search function.
« Reply #2 on: January 26, 2012, 03:18:59 AM » |
« Reply #3 on: January 26, 2012, 03:32:01 AM » |
You cap both 3 and 4, but, thats just the beginning.. Look in the archives or shoptalk for the article written by Quexpress [ Normand ].. Its the best desmog article ever written..
larswlvs
Akron,Ohio
« Reply #4 on: January 26, 2012, 05:52:38 AM » |
I did do all the other things that have to be done for desmog but I capped the T on #3 and #4 and not the carbs separably...was not sure the carbs needed to be connected . Thanks to all,
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #5 on: January 26, 2012, 11:15:07 AM » |
When you are done with the de-smog, there will only be one vaccuum line attached to the back of the intakes...that will be on # 6. If you are not using a vaccum operated fuel vavle, then all the intakes will have plugs on them.
PhredValk
« Reply #6 on: January 28, 2012, 02:44:34 AM » |
Unless you have the Audiovox CC100 cruise control, then you're using the vacuum for that. Fred.
biguglyman
Brockport, NY
« Reply #7 on: January 28, 2012, 05:57:11 AM » |
Is it just California bikes that have to be "de-smogged"?
« Reply #8 on: January 28, 2012, 07:01:38 AM » |
"Is it just California bikes that have to be "de-smogged"?"
No, no bike has to be de-smogged.. Its against federal law to do so.. Some bikes are de-smogged just to help eliminate the possibility of vacuum leaks , stop the pair valve rattle, and clean up the looks of things..
biguglyman
Brockport, NY
« Reply #9 on: January 28, 2012, 07:30:06 AM » |
OK, let me re-phrase the question. Do all Valkyries have the smog plumbing that is removed during the de-smog operation, or just certain models?
JC
The Beast
Franklin, TN
« Reply #10 on: January 28, 2012, 09:01:12 AM » |
Yes, all models can be de-smoged, the California models require a little more because of the extra plumbing.
