February 04, 2026, 03:32:21 AM *
Author Topic: Want to add an IS trunk on Valk Trike  (Read 2133 times)
rmrc51
Palmyra, Virginia
« on: January 27, 2012, 03:58:36 AM »
After convincing myself "NOT" to trade in my Valk Trike, I'd like to add one more option/customization to her if possible.
I'd like to add an Interstate trunk. My Valk is a Standard. (Although with all of the added options it's really a Tourer at this point and she already has an IS gas tank). Not quite sure what I'd need to do this. I know I'll have to get or fashion some type of support structure/rails.
Any and all suggestions and sources are appreciated!  Wink
Here's 2 photos of the back end at present;
« Last Edit: January 27, 2012, 04:22:07 AM by rmrc51 » Logged
VRCC # 30041
Big Mike
I can not remember my last bad day
Taylor MI
« Reply #1 on: January 27, 2012, 05:05:00 AM »
If it were me, I would buy the trunk and mounting pieces. Then take it to a fabricator. There will be no easy install since the trike kit is already complete. If there is a local trike shop, they may be able to give you some help.
Big Mike
VRCC 23871
VRCCDS 0200
With GOD and a good attitude, there is no circumstance that I can not overcome.
rmrc51
Palmyra, Virginia
« Reply #2 on: January 27, 2012, 05:34:35 AM »
That's what I kinda thought.  Undecided  The normal attachment points for the mounting rails are below the top of the trike's back end as seen in the photos I attached.
VRCC # 30041
ptgb
Youngstown, OH
« Reply #3 on: January 27, 2012, 05:56:40 AM »
Get ahold of Bigbuck on here. His wife rides a Mototrike converted trike with a Tsukayu trunk mounted on it. I think that there is custom made bracketry for mounting.
It looks really good. In fact, I think it looks better than the OEM trunk on the Mototrike (goes better with the lines of the trike).
I can attest to the fact that the Tsukayu trunk is really nice. i had one on a 97 Standard and since sold that trunk to MP here on the board who, I believe, still uses it today. Here is a link to a description and photos when I mounted it on my 97; gives you an idea of what they look like: http://www.valkyrieguy.com/tsutrunk.htm
Worth a look...
« Last Edit: January 27, 2012, 06:02:16 AM by ptgb » Logged
MP
North Dakota
« Reply #4 on: January 27, 2012, 06:02:32 AM »
I can attest to the fact that the Tsukayu trunk is really nice. i had one on a 97 Standard and since sold that trunk to MP here on the board who, I believe, still uses it today. Here is a link to a description and photos when I mounted it on my 97: http://www.valkyrieguy.com/tsutrunk.htm
Worth a look...
Yep.  It is still on there!  Looks good.
MP
"Ridin' with Cycho"
rmrc51
Palmyra, Virginia
« Reply #5 on: January 27, 2012, 06:19:11 AM »
Worth a look...
Thanks for the tip!!  cooldude
VRCC # 30041
« Reply #6 on: January 27, 2012, 11:04:21 AM »
I know someone with a couple Interstate trunks for sale. Let me know if interested.
rmrc51
Palmyra, Virginia
« Reply #7 on: January 27, 2012, 11:21:54 AM »
Thanks Joe. I'll first have to look into how I'm going to go about mounting it due to the trike conversion blocking the mounting points for the rails. I'll know more over the weekend.  cooldude
VRCC # 30041
« Reply #8 on: January 27, 2012, 12:33:37 PM »
You will want the IS fender rails, trunk with mounting brackets.
I see you still have your fender rails on the bike, the IS's will have the 4 tabs/bolts that the trunk support will mount too. I still have mine, slightly damaged, from my IS wrecking, for sale.
Otherwise, you could fab the tabs with bolts, and weld them to yours. Depending on your passenger, and how much more room is wanted, would allow you to have a custom fit.
I have mounted the IS trunk to my ACE Tourer. I made a pair of adapters to bolt up to the fender rail bolts, and bolt the stock holes on the trunk mounting braket to the plate. I moved my trunk back about an extra 1 1/2" to get some extra room for my wife. Wired the lights into the stock plug and all works well.
note: took another look at your 1st pic, and looks like you may have to raise the trunk up higher to get over your existing trunk.
« Last Edit: January 27, 2012, 12:43:03 PM by gordonv » Logged
« Reply #9 on: January 27, 2012, 03:07:36 PM »
Yes if you mount it to high to allow your trunk to open it wont be comfortable for the passenger. Maybe the trike co has some ideas.
tank_post142
south florida
« Reply #10 on: January 27, 2012, 03:20:47 PM »
friend had same trike. made one inch plates that bolt to us side rails to lift trunk one inch, rear door opens about 3 inches short of full open , works out fine.
I got a rock Sad
VRCCDS0246
« Reply #11 on: January 27, 2012, 05:33:42 PM »
What version of trike kit is it? When Roadsmith puts together a kit for you, they ask if it's a Std./Tourer or an I/S with the trunk mounted. Reason for it is they cut out part of the rear section of the body on top to accommodate the special brackets they make to mount the I/S trunk. It might be worth a call to them to see what's involved, could save you a lot of extra work and expense. If nothing else, maybe you could at least buy the mounting brackets from them.
rmrc51
Palmyra, Virginia
« Reply #12 on: January 27, 2012, 07:43:21 PM »
All great suggestions here.
I'd like to be able to retain my passenger back rest if possible. I believe this MotorTrike conversion was their first. I can see that there is no way to access the bolts to the side rails without taking the entire rear body off and that's something I don't want to do!
The only option I have is to fabricate some type of mounting to the sissy bar. Maybe the IS trunk might not work, although that's the one I really wanted. I might have to go with one of the other brands as mentioned like the Tsukayu. I'll really look at it closely tomorrow and post here again.
VRCC # 30041
« Reply #13 on: January 28, 2012, 11:15:54 AM »
If you aren't willing to get access to the bolts of the fender rails, then I would forget the IS trunk.
With regards to something else, you might be able to mount a rack on that back rest, and then you can put anything onto that. Something like a Givi, or we had a memeber use an old GL1200 trunk. Looked nice, and they are cheap (sometimes).
shortleg
maryland
« Reply #14 on: January 28, 2012, 02:06:23 PM »
  If that is a california sidscar kit you will have to remove the body
to replace the finder rails for the the trunk.
  Also if I remember corectly the bodys are
different for the IS and standard.
  The IS has a flat place for the trunk.
           Shortleg[Dave]
« Reply #15 on: January 28, 2012, 02:29:33 PM »
Talk to Lady Draco or HIghbinder, they have a Std with the I/S box on it, and she also has a I/S converted to a Trike.
Her rides, look top notch.     I think she said that California Side Car, whose kits she have on both Trikes, is just down the road or close by in Virginia.
tank_post142
south florida
« Reply #16 on: January 28, 2012, 07:58:17 PM »
it appears to be a motor trike kit. normally  the swap the hinges ( top to bottom) but i've it done both ways.
I got a rock Sad
VRCCDS0246
rmrc51
Palmyra, Virginia
« Reply #17 on: January 29, 2012, 02:58:58 AM »
With regards to something else, you might be able to mount a rack on that back rest, and then you can put anything onto that. Something like a Givi, or we had a member use an old GL1200 trunk. Looked nice, and they are cheap (sometimes).
Took a close look yesterday. As mentioned there is no way to access the side rails other than removing the body. I'm definitely not going to do that! At present, I'll just see if there's a way to make some kind of mounting to the sissy bar as I also don't want to loose or remove the passenger back-rest as per Gordonv's statement above.
As yes, it's a Motor-Trike conversion for a standard Valk. Just got her back yesterday from BlueRidge PowerSports in Harrisonburg (Motor-Trike service center) after a full end-to-end servicing including cleaning all carbs. (I can't do this kind of maintenance myself). She's running like a "bat-outa-hell" now, lol.  Evil Now I just have to make sure I run her as much as possible or at least drain the carbs.
Again I appreciate all of the interest and suggestions! Time will tell how, or if it progresses. Thanks again!  cooldude
« Last Edit: January 29, 2012, 03:16:19 AM by rmrc51 » Logged
VRCC # 30041
« Reply #18 on: January 29, 2012, 05:28:38 PM »
Here are a couple of posts. The trunks are mounted on ACE Tourers, which from the back, look just like a Valkyrie Tourer.
Mutazu DMY
http://hondashadowacetourer.yuku.com/topic/12417/New-Trunk-on-the-T
K&G Engineering
http://hondashadowacetourer.yuku.com/reply/97437/Another-Trunk-Mounted-on-a-Tourer#reply-97437
GL1100 - shows how it was mounted
http://hondashadowacetourer.yuku.com/topic/12218/My-T-with-Goldwing-GL1100-Trunk-and-GL1100-Trunk-Mount?page=1
I chose these because they have some nice clear pictures, showing what it would look like.
Then my ACE Tourer with my IS trunk on it. It has been mistaken for a Valkyrie or IS, until someone looks around at the engine. I made a couple of plates from 1/4" steel, which bolted to the OEM bike, and inside the trunk mounting brackets. No modification required.
http://hondashadowacetourer.yuku.com/topic/14197/Valkyrie-Interstate-trunk-on-ACE-Tourer
« Last Edit: January 29, 2012, 05:44:07 PM by gordonv » Logged
