February 04, 2026, 03:33:48 AM *
Author Topic: FYI--- EXHAUST  (Read 1434 times)
bogator
IN GOD WE TRUST------KK4KSN-------
Valley,Al
« on: January 28, 2012, 12:08:39 PM »
  I went for a PGR ride the other day, and I kept hearin a tick-tick-sound, at first I thought that a lifter was rattlin ,----so when I got back ,I went over to brothers shop . his son is 40 sumpin so ---I ask him to listen and see if he could tell what it was---WELL--lo and behold-- not a lifter--it was an exhaust leak on the front left. so I got the gaskets the next day and went over to let him install ---well guess what we found.?? the nuts that hold them on were finger tight, yes -and 1 of them was gone ---so ----he got them installed in about 20 min. I said ---check the right side, and they were loose to.  this info is for all to see ----and to give ya'll a heads up to check those nuts, when you are just in your MAN CAVE and doin nothin get a hand full of wrenches and do some nut checkin. all over the bike. ----------this mite be totally worthless info to some of ya'll,--but ----do it anyway. GOD BLESS---- crazy2 crazy2
SANDMAN5
Mileage 65875
East TN
« Reply #1 on: January 28, 2012, 12:17:25 PM »
I found a few of mine loose one time. Probably time
to check them again. Thanks for the reminder. cooldude
« Reply #2 on: January 28, 2012, 04:33:33 PM »
Be careful not to over tighten these, they will break and then your in it.  But you should check them a couple times a season and if you replaced the gaskets, after the first couple of rides.
YoungPUP
Valparaiso, In
« Reply #3 on: January 28, 2012, 05:23:00 PM »
7ft/lbs!!!
99 STD (Under construction)
