February 04, 2026, 03:32:12 AM *
Author Topic: Risers  (Read 1448 times)
wiplash123
« on: February 01, 2012, 06:07:01 PM »
Does any one know if the risers on a 99 model are the same hight as the 2000
Robdawg13
« Reply #1 on: February 01, 2012, 07:15:12 PM »
Same part # for both years - 53231-MZ0-000
I don't want a pickle
I just want to ride my motor-sickle
« Reply #2 on: February 01, 2012, 10:52:41 PM »
All years are the same.......... about 3-4 inches too short.
pistolchamp
San Antonio, Texas, USA
« Reply #3 on: February 02, 2012, 09:24:55 AM »
Good gosh, I tried to take the factory risers off so I could put on some higher ones and I cannot get the bolts loose.  They are REALLY tight, anyone else have this problem?
« Reply #4 on: February 02, 2012, 09:30:45 AM »
Spray with some liquid wrench, wait, use half inch ratchet/sockets/extension, try to tighten a wee bit before loosening.  Cover your tank and front fender from bar/tool drop.
When reinstalling use antiseize.
Tx Bohemian
Victoria, Tx
« Reply #5 on: February 02, 2012, 09:54:19 AM »
All good advice.
When I removed the aftermarket risers on my bike that the PO installed one side came off like clock work and the other gaulled after the first half-turn. A royal PITA but it did come off eventually.  Did pretty much what Jess said to do.
I wasn't going to re-use these risers so it didn't matter to me if the bolt would've broke off or if it stripped out all the way which either one of these methods wouldn've been better for me.  Unfortunately it unscrewed ALL the way.
Al
