February 04, 2026, 03:32:19 AM
Timing belt adjustment - cold - hot
Topic: Timing belt adjustment - cold - hot (Read 1621 times)
Bigwolf
Cookeville, TN
February 02, 2012, 10:16:29 AM »
I have read in the Honda manual (and in shop talk) that the timing belts should be adjusted to have 5 - 7 mm (0.2 to 0.3 in.) of slack on the long side. I am thinking that is with the engine cold and that is the way mine are set. When the engine gets up to runing temperature, this slack is all gone. So now I am wondering if adjusting the belts with the engine cold might make them a little too tight when the engine is hot. I believe in following the Honda maual for most things but I am looking for actual field experience on this particular matter.
So what works best when setting this adjustment? Engine cold, engine moderately warm or engine at operating temp?
TIA,
Wolf
Westsider
Fort Worth TX.
Re: Timing belt adjustment - cold - hot
February 02, 2012, 11:23:48 AM »
Thats how mine are set, cold,. They seem loose cold and good and snug hot. Not making noise or anything so I guess good. I stay on the loose side of the manual 0.3 cold and no problems. Good question though, I would like to know if im running to tight ?
Paul.
we'll be there when we get there - Valkless,, on lookout....
February 02, 2012, 12:31:49 PM »
They should be set cold.. I set them a bit looser than Honda wants [3/8"] because they seem to run a bit quieter.. These engines stretch a lot as they warm and the belts will tighten..
Westsider
Fort Worth TX.
February 02, 2012, 01:12:06 PM »
I like that idea Patrick, may loosen mine a tad more while its up on the lift now, hot they were very snug, a little more than I thought they would be .
Brian
Monroe, NC
February 02, 2012, 07:09:49 PM »
ditto with the engine cold and almost at 3/8"
Bigwolf
Cookeville, TN
February 02, 2012, 07:50:39 PM »
Thanks for the help. I like the idea of setting the belts a little bit loose when the engine is cold.
Wolf
Reply #6 on:
February 03, 2012, 07:59:59 AM »
The springs on the tensioners are there for a reason.
Honda already did the hard part knowing that the mechanically minded would understand.
The cam belts need very little (to none at all) tension and applying such is seeming to approach the whole matter as regards drive belts on motorcycles and fan belts on automobiles.
A cam belt a little too loose will never result in a problem while the same belt a little too tight can result in accelerated wear-out, breakage, and significant damage.
