March 28, 2026, 11:32:13 PM *
Author Topic: Maintenance Reminder--Tighten those battery cables...  (Read 725 times)
Daniel Meyer
The State of confusion.
« on: February 03, 2012, 11:57:57 AM »
They do loosen up, even on our über smooth Valks...
Loose cables can promote corrosion, cause rough running or power drop-off at high RPM (those ignitions SUCK the power at high rpms) and can also shorten alternator life, and even "prang" the voltage regulator if loose enough.
...that's a protip, non-partisan, cholesterol free, and has nothing to do with running darkside or rear end splines. It may, however, contain peanuts.
See you on the road!
CUAgain,
Daniel Meyer
« Reply #1 on: February 03, 2012, 02:11:30 PM »
'N a schmear of di-electric grease.
