November 23, 2025, 06:44:31 PM *
Author Topic: right side rear wheel bearing  (Read 1030 times)
robin
Get on it and RIDE!!
Hardwick NJ
« on: February 04, 2012, 07:27:40 AM »
Should you be able to pull it out with just your fingers?
NITRO
Eau Claire, WI
« Reply #1 on: February 04, 2012, 07:44:08 AM »
No, that would most definitely indicate a problem.
When in doubt, ride.
Grandpot
Fort Mill, South Carolina
« Reply #2 on: February 04, 2012, 10:49:44 AM »
Heck no, those are PRESS FIT bearings, both sides.
Warlock
Magnolia, Ms
« Reply #3 on: February 04, 2012, 01:36:33 PM »
Had one do this. No big deal. Get you a coke can and cut you a shim for it. I did that and then I took and index around the outer race of the wheel. Problem fixed. It was making a popping sound in a left hand turn. The bearing was moving in the race.
David
