February 04, 2026, 03:24:27 AM *
Author Topic: removing fork caps  (Read 1434 times)
bernie g
« on: February 09, 2012, 07:54:06 PM »
I am taking apart the forks on a valkyrie and am having trouble getting one of the fork caps off, I have tried heating it up with a heat gun and  using a hand impact driver. Does anyone have any ideas on how to get this off with out wrecking it.
Thank you,
Bernie G
lucky_1_chris
Arlington, TX
« Reply #1 on: February 09, 2012, 08:25:00 PM »
Thank you,
Bernie G
Are the forks off the bike? Top pinch bolt loose? Shouldn't be that tight...maybe a previous owner or shop had them apart and damaged the cap.
« Last Edit: February 09, 2012, 08:30:53 PM by lucky_1_chris » Logged
1999 Valkyrie Interstate
bernie g
« Reply #2 on: February 09, 2012, 08:45:12 PM »
The forks are off the bike, I tried putting it back in the tripple tree but ther's no room to get a socket and breaker bar it to lossen it up, i am going to try to make some rubber v-blocks to hold the forks tighter to keep it form spinning like it's doing in the padded v-block thats in the vice now.
Bernie G.
larswlvs
my littlest riding partner
Akron,Ohio
« Reply #3 on: February 09, 2012, 09:02:04 PM »
They are REAL fine thread, I bet the PO has them cross threaded. They should not be that tight. I took mine off with a socket and 3" extension when I replaced my spring while on the bike.
If guns kill people where are mine hiding the bodies
lucky_1_chris
Arlington, TX
« Reply #4 on: February 09, 2012, 09:03:35 PM »
Bernie G.
The trees should be able to hold it tight enough. Oughta be enough room without a fairing. Good luck and welcome to the board.
DFragn
« Reply #5 on: February 09, 2012, 09:26:36 PM »
As mentioned, it shouldn't be that tight. Be careful you can round those caps up real easy.
I usually loosen the upper pinch bolts only, then crack the caps loose, then loosen the lower pinch bolts to remove the tubes.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #6 on: February 09, 2012, 10:21:10 PM »
Yes, this would be the easiest and correct way.  cooldude
States I Have Ridden In
« Reply #7 on: February 10, 2012, 04:36:37 PM »
As was stated: tighten the lower tripletree pinch bolts. Loosen the top pinch bolt, and loosen the cap. A 15/16" box wrench or socket will fit. Use a 1/2" breaker bar with a cheater pipe if necessary.
