February 04, 2026, 05:21:23 AM *
Author Topic: Start Stop switch  (Read 1305 times)
sailer48
S.W.Florida
« on: February 14, 2012, 03:49:40 PM »
I had to replace the start stop switch on my 2000 Valk.Having trouble getting the throttle cables back on. Any suggestions.
« Reply #1 on: February 14, 2012, 04:18:02 PM »
Loosen the bar mount bolts and move the bar to the left and retighten. This should provide enough slack to get it all back together.
houstone
Can't get enough...
Santa Fe, TX
« Reply #2 on: February 14, 2012, 10:25:48 PM »
make sure the tension adjustment is ALL the way loose.  It can be taken off fairly easy, but to get it on, it needs to be completely slack.
Good luck!
Jeff
sailer48
S.W.Florida
« Reply #3 on: February 15, 2012, 09:48:49 AM »
Thanks Sandy,Houston your advice helped,all back together.New problem now. Will post new problem thanks again.
